Author Topic: multi-coin HS-616  (Read 1752 times)
jackiabu
  • Last login:May 18, 2025, 02:29:49 pm
    • http://jackiabu.blogspot.com/
multi-coin HS-616
« on: January 24, 2014, 09:19:50 am »
HI
Today a friend brought me COIN UP. I want to connect it to one of my machines. And pass through MAME.
According to what I read on the site of http://www.ultimarc.com/controldiags.html  Zener Diode need to connect to pass through the IPAC. And  that  for the IPAC will not be damaged.
i have no Zener Diode ,Perhaps because it was connected to the original arcade  machine :-\
My question  what Zener Diode type should I buy? What voltage of Zener Diode?
« Last Edit: January 24, 2014, 09:32:13 am by jackiabu »
  • Last login:Today at 03:50:26 am
Re: multi-coin HS-616
« Reply #1 on: January 24, 2014, 11:18:56 am »
The IPac runs on 5v, so you'll need a 5v zener diode.
Details and a part# link in this thread.
Remember that the band on the zener diode goes toward the coin signal line (reverse biased), NOT toward ground.
jackiabu
« Reply #2 on: January 24, 2014, 12:32:43 pm »
Thanks man i will check it  ;)
