Author Topic: Kade Encoder software won't start. (SOLVED)  (Read 1668 times)
jdbailey1206
« on: January 21, 2014, 07:41:42 pm »
I got my Kade Encoder all wired yesterday and downloaded the software to program my control panel.  My main problem is the software won't load for me so that I can encode my control panel.  When I download the software I am getting the most recent software version that is 1.0.9.2.
My first problem is when the software install is completed.  I receive the following errors:
Error creating shortcut:  C:\Documents and Settings\My Name\Start Menu\Programs\Kade Loader\Kade Loader.lnk
Error creating shortcut:  C:\Documents and Settings\My Name\Start Menu\Programs\Kade Loader\Uninstall.lnk
After the installation is complete I check the Start Kade Software box and the software won't load.  And of course by the shortcut errors I don't need to tell you that the program software won't load from either the icon shortcut or the actual icon in the program folder.
I am running the following specs:
Intel Core 2 CPU
6300 @ 1.86 GHz
3.21 GB of Ram
Windows XP Professional
Service Pack Three.
Any help would be greatly appreciated.  I have also ran the program as an administrator so that isn't a problem.
Also when I start the software from the short cut I get the following error:
C:\Program Files\Kade Loader\loader.exe
This application has failed to start because the application configuration is incorrect.  Reinstalling the software may fix this problem.
Thanks in advance for the help.
« Last Edit: January 22, 2014, 08:11:38 am by jdbailey1206 »
jdbailey1206
Re: Kade Encoder software won't start. (SOLVED)
« Reply #1 on: January 22, 2014, 08:13:39 am »
Found my solution on the Kade Encoder Forum here.  The solution was offered up from Jon from Kade.  All I had to do was install the Microsoft Visual C++ 2008 Redistributable Package and everything was happy.
