Author Topic: Can a monitor be vesa mounted directly onto wood?  (Read 2974 times)
Morphx2
  • Last login:December 14, 2014, 06:19:38 pm
« on: January 18, 2014, 09:44:00 pm »
I have probably around a 1/2 gap between the wood and monitor if I mount it directly.
Can this be done, would it be strong enough?
I tried with a mount I got from amazon, but it gave too much gap between the monitor and wood and the plexiglass would not fit in at all!   :(
Directly mounting it would make it juuuuuust fit
I didn't measure it beforehand :)
Slippyblade
Re: Can a monitor be vesa mounted directly onto wood?
« Reply #1 on: January 18, 2014, 09:45:57 pm »
Most use a cross member of wood with the monitor VESA mounted directly to that, then the cross member mounted in the cab.  That's what I've seen and what I've done.
Morphx2
« Reply #2 on: January 18, 2014, 09:51:29 pm »
I kinda did my own crazy mount for the wood
So I can just buy screws and screw it directly into the wood?
rotate the picture and it will look correct
the middle wood is vertical
Slippyblade
« Reply #3 on: January 18, 2014, 09:55:11 pm »
That should work with no problems.  The only difference between what you are doing there and a "real" VESA mount is the materials involved.  Wood is plenty strong enough.  I recommend getting bolts that are long enough for a washer though, so the bold head doesn't sink in to the wood over time.
Morphx2
« Reply #4 on: January 18, 2014, 10:41:49 pm »
good tips, time to go to lowes early in the morning!
cant believe my mame probject is almost done
its my first project ever (and im 32!)
