Author Topic: Joystick mapping  (Read 3755 times)
parasol
  • Last login:August 22, 2022, 04:39:31 pm
Joystick mapping
« on: January 17, 2014, 05:25:51 pm »
I'm using Mayflash Super Dual Box Pro (PC038)
In the "controller mapping" -> "view" tab, I can see the buttons I'm pressing but when I try to actually map a button nothing happens!
Help pls!
thomas_surles
Re: Joystick mapping
« Reply #1 on: January 17, 2014, 07:17:20 pm »
Maybe you could try the joy to key software and set it up as keystrokes if all else fails
parasol
« Reply #2 on: January 20, 2014, 07:42:05 am »
Im using joytokey for every emulator to have extra commands mapped to my joypad.
Using Joy-To-Key to also control MA seems not possible to me. Because this means to launch joytokey when MA starts, terminate it before certain emu is launched (to be able to start joytokey for this certain emu) and start it again after certain emu + joytokey is terminated.
Also:
I tried another pc with windows7 and fresh MA install, exact same results.
I tried another pc with xp and fresh MA
This leads me to believe MA is not compatible with pc038 usb adapters.
« Last Edit: January 20, 2014, 07:50:23 am by parasol »
thomas_surles
« Reply #3 on: January 20, 2014, 07:34:27 pm »
Have you tried the pre launch and post launch tabs in the emu config
