Author Topic: AimTrak Light Gun?  (Read 3515 times)
BAMBOO
AimTrak Light Gun?
« on: January 07, 2014, 07:33:49 am »
Has Andy said anything to anyone here about when he will be getting more of the AimTrak Light Guns in stock?
And has anyone tried these yet?  Im sure coming from Andy they are gtg.
TopJimmyCooks
  • Last login:May 06, 2026, 09:14:25 pm
Re: AimTrak Light Gun?
« Reply #1 on: January 07, 2014, 11:17:17 am »
aimtraks are great and are probably the best quality solution for LCD displays and are recommended by me.  Check with Arcadeemulator.net (divemaster here on the forum) who is the ultimarc us distributor.  he had some in december.
BAMBOO
« Reply #2 on: January 07, 2014, 02:53:12 pm »
Ah yeah, divemaster, I forgot about him.  Been a while since I have been on here.  Thanks Jimmy!
Caparo8bit
  • Last login:April 28, 2018, 02:13:32 am
  • Hyperspin/Maximus
TopJimmyCooks
« Reply #4 on: January 31, 2014, 09:40:14 am »
That ebay auction is also divemaster.  However, the shipping will be less than $40 if you order two from him directly.  If you're ordering one its a toss up.
Rasterico
  • Last login:April 09, 2014, 05:03:50 pm
« Reply #5 on: February 11, 2014, 04:50:52 pm »
I too would like to know about the stock situation as I'm planning on picking up a couple for my cabinet, incidentally if anyone here has experience with using them I'd like a bit of advice, I plan on mounting the sensor bar just underneath the marquee overhang instead of behind the screen and was wondering if this would work well enough?
Here's a picture of my cabinet so you guys can gauge
TopJimmyCooks
« Reply #6 on: February 11, 2014, 09:08:38 pm »
should be fine mounting the light bar a little high, since you can calibrate the guns.  as far as putting it way in front of the screen, not sure about that.
Rasterico
« Reply #7 on: February 12, 2014, 05:30:24 am »
Ahh right, I was hoping to get away without having to cut away any of the plexi surrounding the monitor and maybe just drill a small hole to feed the cabling through into the cabinet itself so the sensor bar is as flush as it can be towards the back of the marquee overhang, perhaps I could try it anyway and if it's a no go then just go the whole way and cut to fit the sensor so it's inside. Thanks for your reply though :)
Still like to know the stock situation of these though as I plan on ordering in the next couple of weeks to get my Point Blank and Virtua cop fix!
