Author Topic: S-Video / Composite -> RGBS  (Read 3361 times)
draco
  • Last login:December 19, 2003, 07:59:04 am
« on: November 27, 2003, 10:00:42 am »
I'm looking to use non-RGB video sources in my cab such as old consoles and the like. I already have a nice original 28" Hantarex arcade monitor in there which is great, but I want to connect s-video and composite equipment into it. There are a number of 'VGA boxes' on the market for hooking consoles etc. to VGA monitors, but all the ones I've seen scan-double to 31khz. I'm wondering if anyone has seen one which will allow you to disable the scan doubling, or a hack to an existing one, so you just end up with a composite/s-video to RGBS decoder? This is really bugging me because it's a bit of electronics that's in all TV's by their very nature and should b easy to get hold of... but the only readily available ones I've seen are multi-purpose pro convertor boxes that cost upwards of $200.
StephenH
Re:S-Video / Composite -> RGBS
« Reply #1 on: November 27, 2003, 05:42:59 pm »
Here is a page that explains how to connect RGB and Jamma connectors to consoles.
http://www.mameworld.net/pc2jamma/
draco
« Reply #2 on: November 28, 2003, 06:04:29 am »
Aye, tis a cracking page that and has helped me along many times in the past while learning this stuff - but what I'm really after is some flexibility to use the arcade monitor as something more general by giving it the ability to accept s-video and composite inputs. Granted, it's possible to get RGBS out of most things one way or another, but I'd still like to have the option  ;)
darklegion
  • Last login:February 11, 2005, 11:27:02 pm
« Reply #3 on: November 28, 2003, 06:17:24 am »
Nearly all consoles output rgb but for a few(the 3do i believe is one) so your better off taking rgb straight from the console rather than using a converter.The quality will be much better this way and the cables will cost virtually nothing to make.Check www.gamesx.com for details..
DL
tom61
  • Last login:September 18, 2017, 12:46:56 am
« Reply #4 on: November 28, 2003, 06:30:24 pm »
Look on Ebay in the Coin-Op section for NTSC to RGB converters. That's where I got mine. Most only take composite in though.
PacManFan
  • Last login:December 06, 2005, 12:18:56 pm
    • Kymaera Home Page
« Reply #5 on: November 30, 2003, 10:53:58 am »
Sorry to hijack this thread, but I was going to post about the same thing, I've got my arcade cabinet set up so that my kids can watch movies (VCR) on it, I just got a nice 25" Hantarex monitor that I'm going to put in my cabinet to replace the 25" crappy RF-only tv that's in there now. I want my kids to still be able to watch movies on it, so I need some sort of Composite to RGBS converter like the "Dragons Lair/ Space Ace" Composite to RGB board. Is there a commerical site or buisness that manufactures these? Can I build my own circuit using a NTSC to RGBS comb filter?
-PMF
All Hail Smezznar! The Giant purple centipede of Omnicron 5. Regail him with your odiferous offerings of onion powder!
tom61
« Reply #6 on: November 30, 2003, 05:03:16 pm »
None that I've found. I looked for quite a while (maybe that's been changed, I haven't looked for a while). Happs used to carry one for the K7000 series monitor (not sure if it was compatable with other mons.), but no longer has any in stock)
All schematics I found for NTSC to RGB circuits were either more expensive than buying a complete unit on Ebay, or nearly impossible to find the chip for.
