Author Topic: how do i wire up a start button for my pc?  (Read 3642 times)
yup
  • Last login:February 26, 2004, 02:31:15 pm
« on: November 26, 2003, 02:40:52 am »
checked the newbie faq, couldnt find that there...
BASICALLY...i'm using an old trivia whiz cab, which already has a button in the back of it, which i want to use for the power switch. i want to hook it up so that when i press that, my pc turns on. btw i'm using an atx psu for my pc. i have a vague idea of how it works, i know i'm supposed to have a jumper +wires on the on/off pins on the mobo, but i'm not exactly sure how the wiring/connection to the button is supposed to work
any help would be greatly appreciated...thanks in advance
DeathMonk
  • Last login:April 03, 2015, 02:01:12 pm
    • MameStation.3
Re:how do i wire up a start button for my pc?
« Reply #1 on: November 26, 2003, 09:56:40 am »
The button would work exactly like the button on the atx case.  Wire the button to the "atx power" leads on your mobo.  That should work for turning the computer on.
Now with cup beer holders!
eightbit
  • My cab is never done...
« Reply #2 on: November 26, 2003, 10:34:30 am »
Trace the wires from your power button to the mobo. Figure out which 2 wires it is. You can then splice into the wires or do what I did. I pulled the connector off the mobo taken the new wires (small gauge) and shoved them into the plug and then plugged it back into the mobo. You shouldn't be able to hurt it but try this at your own risk.
yup
« Reply #3 on: November 27, 2003, 02:24:54 am »
the problem is...i never had a power button to begin with (or even a case for that matter). this comp was just thrown together with random stuffs, so i dont have an existing power button example to work off of. a little more descriptive-ness would be appreciated...the last 2 posts helped but i'm still having a little trouble understanding exactly how everything should hook up or even what kind of equipment is involved (jumpers, what kind of wires, etc). thanks
PedroSilva
  • Last login:August 01, 2018, 08:37:57 am
  • Grettings !
« Reply #4 on: November 27, 2003, 09:42:17 am »
Hi,
The newer boards have an option for what to do after a power failure. One of the options is "start pc" or something like it. If you configure the bios with that option, you can then use a normal "on/off" switch to start the PC.
Hope it helps ...
slycrel
  • Last login:June 25, 2025, 07:42:34 pm
  • Mmm... Portal.
« Reply #5 on: November 27, 2003, 12:00:37 pm »
  Look around on your motherboard and see if you can find the manufacturer and a serial number or model number.  You can probably find a manual for it on the company's website.
  You're looking for a row of jumpers probably 15-20 pins long two pins wide.  Your speaker, HDD LED, power button, etc should all go in here somewhere.  It may even be marked on the motherboard itself.  Generally they are in the opposite corner from the outside connections (ps/2, USB, parallel, etc)
  You'll need to attach the ground wire from the button to the ground pin and the other wire to the other pin.
  Good luck.
yup
« Reply #6 on: November 28, 2003, 02:03:13 am »
ok thanks, i'll give it a try when i get back to school
