Author Topic: Very Standard/Basic Cabinet  (Read 1395 times)
coolbrickmovies
  • Last login:November 26, 2003, 01:45:40 am
« on: November 26, 2003, 12:51:43 am »
I've looked around this website for quite some time and have seen some very inspiring advanced cabinets.  But what I decided to do is to focus my first cabinet completely on making a 4-player, joystick-and-button cabinet without any rollers, etc.
Basically, I'm trying to build a cabinet like Gauntlet, but with more buttons.
Does anyone have a good suggestion for recommended numbers of buttons per player? I want to make sure that I have enough for games like D&D Tower of Doom.
Also, can anyone offer a good idea for a layout that would allow all these player?  Namely, a good pattern for setup of buttons.
Thanks very much!
TalkingOctopus
    • My Arcade
Re:Very Standard/Basic Cabinet
« Reply #1 on: November 26, 2003, 01:25:44 am »
Use 6 buttons for players 1 and 2 and 4 buttons for players 3 and 4.
I made a 4 player cabinet that was based off of the very standard Lusid Designs.
Check it out: http://webpages.charter.net/rbecker5/
Note: There are control panel and cab plans (Lusids) in the download section.
Good luck!
coolbrickmovies
« Reply #2 on: November 26, 2003, 01:47:05 am »
Thanks!  That looks great, and I found the controller template at Lusid's site.
As far as each set of six buttons... how did you configure them?  Specifically, I mean which button is Button 1, which in Button 2, etc.
May I ask what the six black buttons at the top do?  I assume that four are for coin drop... but I could easily be wrong.
« Last Edit: November 26, 2003, 02:02:14 am by coolbrickmovies »
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #3 on: November 26, 2003, 07:54:05 am »
  Would this layout still work for running console emulators like PSX, N64, etc that have 4+ buttons on the joysticks?
/S
eightbit
  • My cab is never done...
« Reply #4 on: November 26, 2003, 09:59:35 am »
/S
If your hacking for 4 player console games then you probably want to add more buttons to p3 and p4. Most console games are not good for a cabinet. They are meant to be played for hours at a time, not standing in front of a crowded control panel. So you need to decide what you want to play and how often your going to play with more players.
TalkingOctopus
    • My Arcade
« Reply #5 on: November 26, 2003, 01:29:07 pm »
They are not for coin drops.  I have a Happ over under coindoor.  I decided to put 6 admin buttons.  Here is the layout and their functions in MAME:
Button 1: Enter
Button 2: tab (Pause)
Button 3: left mouse (Main Menu - default is tab in MAME)
Button 4: right mouse (Dipswitches/Gamesettings - default F2 in main)
Button 5: ` (Brings up volume control ect... in MAME)
Button 6: Escape (Exit)
I think this is probably more admin buttons than people normally use.  Only a pause and exit button are recommended, but even those are unecessary.  However, I do use all of my admin buttons.  I like the ablity to turn down the volume through software, raise the difficulty of the game, and remap keys if needed.
