Author Topic: Need help with mala layout editor.... hope this i sthe right spot for post  (Read 4991 times)
CrazyArcade
  • Last login:April 02, 2014, 12:49:29 pm
  • Found MAME/MaLa... took me back about 20 years
Hello,
Im trying to add 2 videos to my layout. The problem I am having is the properties box to specify the path for the video only shows for 1 of the video objects, specifically vidoe2/layout. Im using the latest version of mala v.174.
Thanks in advance.
« Last Edit: December 04, 2013, 08:45:23 am by CrazyArcade »
Re: Need help with mala layout editor.... hope this i sthe right spot for post
« Reply #1 on: December 04, 2013, 10:50:50 am »
IIRC, Video window 2 doesn't change with the game.  It's the same video playing all the time, so the path is set in the layout editor like the background pic is.
Video Window 1 changes with the game and is set up the same way as the pics.  The path to it is specified in Mala options, not in the layout editor.
http://wiki.arcadecontrols.com/wiki/Mala_Config#Pictures_and_Videos
CrazyArcade
« Reply #2 on: December 04, 2013, 11:10:07 am »
So, your saying that video window 1 works like the snaps? Can it be defined as a "default" video or .gif if no video/.gif exists for the selected game?
« Reply #3 on: December 04, 2013, 11:12:10 am »
Not that I'm aware of.  Even if it could be, it would probably restart every time you switched the highlighted game in the list.
CrazyArcade
« Reply #4 on: December 04, 2013, 11:35:04 am »
Ok, so I have the snaps defined in MaLa options as c:\MaLa\MaLa174\Customs\Snaps.... where do I define the video path for video 1? Currently in my mala.ini it is configured as c:\mala\mala174\customs\vids\gif.gif which is under the [Mame] header.
« Reply #5 on: December 04, 2013, 12:17:30 pm »
Start Mala, right click anywhere on it and select Mala Options, then click on the MAME Config tab, then Pictures and Videos tab under it.
Just like in the link I posted above.
CrazyArcade
« Reply #6 on: December 04, 2013, 12:41:29 pm »
My apologies, I didn't see the link you posted in your first response. I will try this when I get home tonight. And thanks for your help thus far.
CrazyArcade
« Reply #7 on: December 04, 2013, 04:33:29 pm »
Ok, so I tried what you said and it is working... not how I want it to but I now have two videos displaying. I appreciate all your help.
