September 09, 2025, 02:21:37 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon
through our link. Thank you!
Well, that was weird. Outage sorted out. Thank you SirWoogie for saving the day!
Main
Software Forum
MAME game minimizing when playing 2 player with Hyperspin - SOLVED
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: MAME game minimizing when playing 2 player with Hyperspin - SOLVED (Read 4793 times)
kahlid74
Trade Count:
+1
Full Member
Offline
Last login:January 01, 2021, 12:42:56 pm
Gaming for a better future!
on:
November 21, 2013, 10:16:46 am »
I found a few posts in the wild about this and thought I would collapse them into one in case anyone else has this issue in the future. The issue is when playing a 2 player game in MAME and player 2 hits buttons 2 and 3 simultaneously. This is with default MAME keys. Q and S are mapped as player 2 buttons 2/3 and when pressed together are also a AHK for Hyperspin called "exitscriptkey". I found no reason to need the ExitScriptKey so I removed it from the AHK.
Install Auto Hot Key onto the computer you are using for emulation (You need this because you have to recompile the AHK script
Go to your root Hyperspin folder
Find a file called
HyperLaunch.ahk
Right-Click the file and select
Edit Script
Notepad should open. Click edit, and select search
Search for
exitscriptkey
It will be found three times. Each line it is found on you need to REM out. To do this simply put a SEMI-COLON at the front of the line
Now search for
GET AND CHECK PATHS
Look for
emuPath := GetFullName(iniEmuPath)
Change it to
emuPath := iniEmuPath
Look for
romPath := GetFullName(iniRomPath)
Change it to
romPath := iniRomPath
Save and close the file
Right-Click on
HyperLaunch.ahk
and select
Compile
(NOTE - Compile may fail if you have launched a MAME game through Hyperspin. Restart and do the above BEFORE running any games)
At this point you should be all set. Q and S will no longer cause MAME to minimize and the error about / paths will also be resolved.
Credit -
http://www.hyperspin-fe.com/forum/showthread.php?10081-quot-Make-sure-your-paths-contain-a-backslash-on-the-end-quot-Help
- POST #7
http://www.hyperspin-fe.com/forum/showthread.php?6321-NEED-HELP-How-to-edit-HyperLaunch-ahk-to-disable-quot-exitScriptKey-q-amp-s-quot
- POST #6
Logged
GWOZDZilla
Trade Count:
0
Jr. Member
Offline
Last login:August 06, 2015, 09:04:29 am
I want to build my own arcade controls!
Re: MAME game minimizing when playing 2 player with Hyperspin - SOLVED
Reply #1 on:
May 22, 2015, 11:17:34 am »
Thanks for doing the leg work and finding this info out. I'm going to try it when I get home from work tonight and report back with my results for anyone else that may stumble upon this post (I'm sure it will work, just wanted to give confirmation)
Logged
somakurusu
Trade Count:
0
Jr. Member
Offline
Last login:November 02, 2015, 05:21:38 pm
Reply #2 on:
September 16, 2015, 07:54:11 pm »
I cannot find that file to compile at all, I even redownloaded hyperlaunch and it still doesn't exist for me. Please help, this really sucks that it crashes.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Software Forum
