Author Topic: Thomson a68elm02x021 - Need Help Identifying specs on monitor  (Read 1496 times)
trixunlimited
  • Last login:November 20, 2013, 12:24:25 pm
« on: November 18, 2013, 12:18:15 pm »
I just recently purchased a Dance Dance Revolution Korean cabinet and the monitor had been replaced with this Thomson Monitor.
Tube # A68ELM02X021
Serial # D-GAM40206
I want to put Open ITG in the Machine (an open based version of DDR that runs on a pc) but I wanted to know what resolutions this monitor can handle and whatnot.
Attached are pictures of said monitor, any help is welcomed
grantspain
  • Last login:July 25, 2025, 09:21:43 am
Re: Thomson a68elm02x021 - Need Help Identifying specs on monitor
« Reply #1 on: November 18, 2013, 01:49:50 pm »
looks like a wells gardner d9400 from what i can see-some better photos of the chassis would help more
if it is a d9400 then it runs cga to svga
trixunlimited
« Reply #2 on: November 18, 2013, 01:54:22 pm »
Thank you for getting back to me so quickly, I will take some more pictures when I get home from work of the board/chassis.
I really am appreciative of the help.
trixunlimited
« Reply #3 on: November 18, 2013, 02:48:09 pm »
So after zooming in on the picture and comparing boards, you are 100% correct it is a d9400 Grantspain I really appreciate the help
for any other people who need it
http://www.wellsgardner.com/pdf/Spec/D9400_SPEC.pdf
