Author Topic: Mala loses focus at startup on windows 7  (Read 1448 times)
severdhed
  • RIP Dinosaur Hippo
« on: November 06, 2013, 11:39:55 pm »
i'm running mala in windows 7 x64. mala is in the startup folder, but once it launches, the start menu is partially visible on top of mala, and i have to click on mala to get it to work.  is there any easy way to resolve this?
bimm25e
  • Last login:July 30, 2024, 08:44:11 am
Re: Mala loses focus at startup on windows 7
« Reply #1 on: November 07, 2013, 10:45:50 am »
anything else in your startup folder? make sure MaLa is last on the list
Fursphere
  • Last login:April 16, 2026, 04:31:49 pm
« Reply #2 on: November 07, 2013, 02:48:37 pm »
With Hyperspin - the trick is normally to disable all the desktop enhancement stuff.
« Reply #3 on: November 07, 2013, 02:50:28 pm »
Pretty sure badmouth fixed a similar issue. Check mala forum.
« Reply #4 on: November 07, 2013, 03:06:44 pm »
Something is launching after Mala and taking focus away.
run msconfig and disable all startup items you don't need.
(I also ran services.msc and changeed anything set to "delayed start" to plain automatic, but in retrospect I don't think it was necessary)
I narrowed mine down to the xonar sound card software which I wanted running for the EQ.
There was no way to make it start any faster.
The solution was to place a shortcut to Mala in the startup folder rather than checking the box to have it start with windows.
That delayed Mala enough that the other program didn't take focus away.
severdhed
« Reply #5 on: November 07, 2013, 03:55:49 pm »
Awesome, I'll check that this evening hopefully. I do have it as a shortcut in the startup folder, along with an autohotkey script..I'll look through the ms config
Sent from my Galaxy S4 using Tapatalk 2
