Author Topic: Hooking up arcade monitor to PC  (Read 1768 times)
DAmnb
  • Last login:July 28, 2011, 03:35:40 pm
  • R-Type for president!
    • TheGameCollector
« on: November 22, 2003, 03:57:41 am »
So I want to use an arcade monitor with an old comp (pre AGP so no ArcadeVGA for me).
The thing is diffrent people say diffrent things, under the monitor section here at BYAOC most just say R,G,B Ground HSync Vsync, but on the PC to Jamma page you need all the RGB grounds, Sync ground and they use composite sync.
Anyone care to elaborate abit on this?
menace
Re:Hooking up arcade monitor to PC
« Reply #1 on: November 22, 2003, 07:40:13 am »
My sharp image monitor takes R,G,B to r,g,b with composite sync from the jamma connector connected to the Hsync+ and V sync- with jamma ground being connected to pin 4 (ground) on the chassis.  Check your monitor info--it should tell you how its to be connected.  Or alternatively bob roberts has some connection tips.
DAmnb
    • TheGameCollector
« Reply #2 on: November 25, 2003, 06:13:51 am »
Might add that its a Hantarex MTC9000 and that it still wont give me a correct image, any help would be great.
menace
« Reply #3 on: November 25, 2003, 08:55:00 am »
Possible to take a picture of the image?  might be easier to address problems--also, what is your current hookup?
