Author Topic: Rowe Error codes reset  (Read 14369 times)
Z0MBIE
  • Last login:March 04, 2014, 06:13:03 pm
  • Dead and loving it!
« on: November 04, 2013, 09:13:17 pm »
What's the procedure to reset the error codes in a Rowe cd-100h jukebox?
ed12
Re: Rowe Error codes reset
« Reply #1 on: November 04, 2013, 09:44:56 pm »
clering error/warnings from memory
1 enter service mode
2 press 6
3 press 1
4 press popular it will blink at u
note
if already  in service mode ,or u want to start over,hold reset switch and
repeately press popular until display shows service mode,then start at step 2
that is right out of the trouble shooting guide
ed
Z0MBIE
« Reply #2 on: November 04, 2013, 09:57:09 pm »
Thanks! but keeps coming back to error 53
« Last Edit: November 04, 2013, 10:14:57 pm by Z0MBIE »
ed12
« Reply #3 on: November 04, 2013, 10:28:32 pm »
error code 53
outer cam switch always open
meaasage means
mechanism control thinks a switch is not working
proable cause
1 a switch
2 a short or open
3 the mechanism control
ed
« Last Edit: November 04, 2013, 10:31:57 pm by ed12 »
Z0MBIE
« Reply #4 on: November 04, 2013, 10:43:35 pm »
ya, I tested it with a continuity tester and is working so for s&g i disconnected it cleared codes again and now code 50 comes up first.
ed12
« Reply #5 on: November 04, 2013, 11:06:54 pm »
error code
50,51,52,53
50 inner cam switch always colsed
51 inner cam switch always open
52 outter cam switch always colsed
53 outter cam switch always open
ed
Z0MBIE
« Reply #6 on: November 04, 2013, 11:11:09 pm »
hmmm that plastic cam is holding the inner switch closed.
ed12
« Reply #7 on: November 04, 2013, 11:14:19 pm »
wind the cam back
so as to realse the switch
see if the control boards makes it enguage again ?
if so u are looking at the error to posts down
mech control board
ed
Z0MBIE
« Reply #8 on: November 04, 2013, 11:28:22 pm »
I'm unable to move the cam in either direction with my fingers.
ed12
« Reply #9 on: November 04, 2013, 11:54:36 pm »
power unit down and try
if not remove mech from machine
take it apart to point  where u can do it
soory bud but the errors codes do not lie
ed
Z0MBIE
« Reply #10 on: November 04, 2013, 11:58:17 pm »
Tomorrow's project will let you know. Thanks!
Z0MBIE
« Reply #11 on: November 05, 2013, 04:11:38 pm »
Update- it turns out the shaft on top was seized so I had to take that out and clean it up and lube and put back in. So now it will put on a cd and play but you can't hear it really unless you put your head right to the subs. I can hear the amp is on and hissing when I crank the volume up. I even tried putting the whole thing into another jukebox but get the same. Could a bad laser cause this? :banghead:
