Author Topic: Pacman cabinet question.  (Read 3065 times)
thehammer12
  • Last login:October 24, 2021, 01:46:34 pm
  • Arcade Breaking Specialist
« on: October 29, 2013, 01:33:20 pm »
Im looking at the Pacman plans from Jakobud.com and Im wondering if grooves or "dado joints" have to be made for the side wood/monitor brackets and roof of the game? or is it just nailed and glued in? I made some arrows in the pic to show what im talking about.
« Last Edit: October 29, 2013, 03:56:41 pm by thehammer12 »
CaptainMarvel
  • Last login:May 03, 2020, 04:49:55 pm
Re: Pacman cabinet question.
« Reply #1 on: October 29, 2013, 05:53:29 pm »
From what I've seen in other's projects, they're pretty much screwed or nailed in.
(though I'm sure it wouldn't hurt to glue as well).
I suppose you could dado them in as well.
TOM
Understanding that you may not see success instantly, but that all your good decisions add up to a cumulative success over time is what separates those who "get there" and those who don't. Every day you either get further away from your goals, or closer to them . . . Its up to YOU."
thehammer12
« Reply #2 on: October 29, 2013, 06:13:38 pm »
Well I was trying to avoid going the dado route, so If its not a must then that works for me.
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #3 on: October 29, 2013, 09:13:12 pm »
They use dado for more surface area and glue.  The glue is the powerhouse here.  If you don't do dado you need to use screws or 15ga nails or lower and glue.  That is if its a traditional arcade monitor.  If its just an LCD tv you could get away with smaller nails and glue.
thehammer12
« Reply #4 on: October 30, 2013, 04:49:12 pm »
Its a traditional arcade monitor, yeah I will definitely go with the nails and glue.
