Author Topic: Monitor has no frame, can I use wood?  (Read 1753 times)
thehammer12
  • Last login:October 24, 2021, 01:46:34 pm
  • Arcade Breaking Specialist
« on: October 23, 2013, 07:29:29 pm »
I got a hanatrex polo monitor with chassis but no frame, was gonna use some angle iron or metal bars from home depot and rig a solid one up. But I saw another user make a frame out of wood.
Is there any harm in using wood?
Re: Re: Monitor has no frame, can I use wood?
« Reply #1 on: October 23, 2013, 10:37:30 pm »
As long as you don't have any metal screws in the wood touching the metal on the monitor, you shouldn't have any issues.
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
« Reply #2 on: October 27, 2013, 05:14:03 am »
the problem with wood comes with the size of the tubes .  a 29 or 33 inch tube + chassis + frame will be around 30 kg weight , so everything has to be done very solid . from electrical point of view there isnt a prob with wood. all radios , tvs from the sixties
are using a wooden cases  . a metal mounting frame is sturdy and build in no time . u only have to be careful with the isolation .
