Author Topic: AMI Rowe 1995 Storm WP100 CD Pro Skipping some tracks  (Read 5659 times)
Ganners62
  • Last login:October 24, 2013, 05:08:10 am
« on: October 23, 2013, 09:32:41 am »
I have an AMI Rowe WP100 Storm juke. The problem is that I have a lot of 'burnt' CD's in the unit as I don;t want any originals scratched. The CD's can be 17 or even 20 tracks long. All work ok. However, sometimes on a CD a track will 'jump'. I copy these at the lowest 7x burn rate. I have cleaned the lens on my CD Pro unit. I have cleaned the drop mechanism and the cd holder 'thinking that there may be a problem with the cd not being held correctly'.
Does anyone have any ideas on this ? The burnt track always fails at the same point. It is random on the CD's I have copied.
Most of my cd's are converted from mp3 to WAV although I copy directly from WAV on originals.
Ken Layton
  • Guru
  • Technician
Re: AMI Rowe 1995 Storm WP100 CD Pro Skipping some tracks
« Reply #1 on: October 23, 2013, 12:40:59 pm »
Technically, the jukebox is not supposed to play burned CD's. It was designed to play commercially manufactured CD's.
Ganners62
« Reply #2 on: October 23, 2013, 01:56:48 pm »
Yes I understand that. A few originals do jump sometimes. I have had the CD unit out today and given everything a clean. Re-seated the unit and things seem to be going ok...fingers crossed!
Ganners62
« Reply #3 on: October 24, 2013, 02:58:44 am »
Ken,
Is there a specific electrical contact cleaner that should be used to clean up contacts in the Jukebox ?
I think mine needs a good clean and I need to ensure that all contacts are good. Also do you recommend any specific cleaning agent for the carousel drive unit?
Thank you
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
« Reply #4 on: October 24, 2013, 08:21:18 am »
Hello Ganners62,
My advice is not to use any type of spay cleaner, lubricantion etc.
Lubrication is only in required in a very small quantity and only on a few specific locations.
Regards
Alan
Alan Hood
ami-man
UK
DLinkOZ
  • Last login:March 22, 2017, 08:12:46 am
    • The DaveCade
« Reply #5 on: October 24, 2013, 02:04:10 pm »
I had the same experience with the CD Pro and burned discs - they *mostly* worked.  It seems as though that's simply how it is.
dddirtman
  • Last login:April 29, 2014, 04:38:42 pm
  • juke tech
« Reply #6 on: October 25, 2013, 03:00:23 pm »
you are correct assuming a cdm 12 pro(which is common) in the wp100,i operate  10 of those machines
i find the 12 pros sensitive to the quality of the cds or cdr's used...
if u must use cdr's get good ones and burn them at a slow speed(less byte errors in burn)...
but if u r getting a skip issue on (real) cd's u may have a faulty player..
a good clean and lube may fix if the laser is good
rowe sells a lube kit for cdm 12 pro players(u may have to contact a distributor to get one though)
dave
donal vending corp.
