Author Topic: Whats the name of connector I'm looking for...  (Read 1253 times)
« on: October 21, 2013, 11:32:50 am »
I want to attach the wiring harness from a JLF to a ZD encoder.  However,  the harness only comes with the connector for the stick side. Can someone give me the name of the five pin female connector I'm looking for so I buy the right thing?
JDFan
Re: Whats the name of connector I'm looking for...
« Reply #1 on: October 21, 2013, 11:50:50 am »
I believe you mean this 5-pin joystick cable -- when ordering the encoder just be sure to order it with the right wiring and it will be included.
IF you already have the encoder and not the correct wire Happmart has them available Here unfortunately they only sell them there in lots of 100 pcs. but it might help you track them down. ( http://www.happmart.com/Pro_Details.aspx?id=530&px=9&sid=116 )
« Last Edit: October 21, 2013, 12:03:22 pm by JDFan »
« Reply #2 on: October 21, 2013, 12:49:58 pm »
Thanks. After some online research its looking seriously like the JST XH five pin connector is my hucklebery. Will confirm for posterity if this is tthe case.
MonMotha
« Reply #3 on: October 21, 2013, 12:59:40 pm »
That's indeed a JST XH.  You can buy them in singles from Digi-Key, including the crimp contacts.
They're also cloned by numerous manufacturers in China.  "WST" seems to be the most common.
