Author Topic: 138 in 1 controls not working.  (Read 1915 times)
ChristopherDXS
  • Last login:October 27, 2013, 01:05:11 pm
« on: October 19, 2013, 07:03:32 pm »
Yes, I am new here and to building so please be gentle.
I have seen this topic posted before but I couldn't find an answer.
I installed a 138 in 1 PCB - all of the wiring is correct but I think the issue is that it is not on "free play" but I can't access the system settings if the buttons aren't working
When I power up and at the elf menu, I hold down the 1P button and it takes me to a screen that says "Press S1 to set up" and none of the buttons are responsive. The buttons are also unresponsive in the Game List screen but if I let it run until the Defender screen saver comes on and hold the 1P button it gives me the option to "Continue" or "Exit" - if I choose Continue, nothing happens, if I choose Exit I return back to the Game List screen and start all over again.
Please, any help would be greatly appreciated since this is only my second build and I don't know anyone with any knowledge on this. I'm sure it's something simple but in the meantime, I'm over here tearing my hair out.
Thanks in advance.
tron84
  • Last login:November 15, 2017, 06:45:56 am
Re: 138 in 1 controls not working.
« Reply #1 on: October 19, 2013, 08:19:46 pm »
Sounds like it is not wired right.
The buttons should work on free play, so that has nothing to do w/ it.
ChristopherDXS
« Reply #2 on: October 21, 2013, 03:48:37 pm »
I tried the manual but it doesn't read very clear.
All I need to know is how to set it to free play.
BobA
  • What Me Worry?
« Reply #3 on: October 27, 2013, 11:39:00 pm »
So did you press the S1 button on the PCB?  If so what was the result?
