Author Topic: Polished T-molding  (Read 5179 times)
rablack97
Polished T-molding
« on: October 18, 2013, 11:34:34 am »
Hello Folks,
Any ideas on how to polish t-molding so it looks like this.
JDFan
Re: Polished T-molding
« Reply #1 on: October 18, 2013, 12:15:01 pm »
Would think that Armor-all would work (it definitely does similar on car dashboards etc. when used on them)
rablack97
« Reply #2 on: October 18, 2013, 12:46:51 pm »
That's a shine enhancer, this was polished, I want the same finish that's on arcade buttons.
JDFan
« Reply #3 on: October 18, 2013, 01:29:56 pm »
They make polish also !
Ultra Shine Liquid Polish
Enjoy an unbeatable high-gloss shine
Now you can help restore your car’s paint to the ‘like new’ appearance it deserves with Ultra Shine Liquid Polish. A special blend of carnauba wax and advanced polymers works to help rejuvenate dull and faded paint, make fine swirls invisible and deliver a shine that will deliver a high-gloss shine.
404
« Reply #4 on: October 18, 2013, 02:25:11 pm »
My first guess would be an average plastic polish with a drill, buffer or dremel buffing wheel and some plastic headlight polish
rablack97
« Reply #5 on: October 18, 2013, 02:36:27 pm »
woohoo thanks guys.......
I read some other tuts, and they mentioned sanding first with a fine grit sandpaper and finishing off with 2000 grit....then polish.
Do you see a need for that or just use polish and a buffing wheel.
404
« Reply #6 on: October 18, 2013, 02:49:19 pm »
I haven't done a whole lot of buffing to plastics in quite a while.
If i were doing this, i would just test using various polishes on a scrap piece of molding. if that doesn't work out, i go the sandpaper route if you can find 2000 grit readily available at your local hardware store. Your best way to combat this with sandpaper is to do a dry run first. then wet-sand using the same final grit twice. Once with just bare water and the second time using waster and dishwashing detergent. Then polish.
404
« Reply #7 on: October 18, 2013, 09:02:16 pm »
I was sitting in the garage and realized i had a spare chunk of red T-molding, fine sandpaper and various buffing compounds laying around here. You can already scratch using a dremel and a felt pad from your polishing.  I tested using a standard medium strength felt pad and various compounds but the T-molding i have here is just too soft for the speed of the dremel and a felt pad. Nothing i tried would prevent burn in swirls on the T-molding.
You would be better off trying a standard drill and a foam or very soft cloth polishing pad may be best.
« Last Edit: October 18, 2013, 09:09:09 pm by 404 »
rablack97
« Reply #8 on: October 18, 2013, 11:33:11 pm »
Yeah i figured dremel would be to concentrated. i got some t-molding i can toy around with, gonna get some polish tomorrow. Post some pics of the results....
thehammer12
  • Last login:October 24, 2021, 01:46:34 pm
  • Arcade Breaking Specialist
« Reply #9 on: November 01, 2013, 02:56:32 pm »
I actually just saw what looked like stainless steel t molding, but It was plastic with a stainless steel polish "look" on it.
I was pretty impressed with it, it looked like a mirror.
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #10 on: November 05, 2013, 10:41:00 am »
Yeap, I would use a Dremel and do a rough/fine sand and then a buffing.  Everything stated above is the way to go.  Late to the party as always :(.
