Author Topic: CP build question - mounting joysticks  (Read 3479 times)
rhys
  • Last login:March 13, 2014, 09:43:56 pm
« on: October 13, 2013, 09:29:31 am »
I'm building my first CP.  Have the template done, ready to through on my CNC mill.  BUT - before I mill this thing, I have a question about mounting the Happ competition joysticks.  I plan to put a laminated self adhesive vinyl overlay on the top, so I want a nice, smooth, unmarred surface to apply it to.  Therefore, I plan to under mount the joysticks.  I don't want to loose 3/4" of the stick height though, so I added a pocket for each one to mount into.
Problem is, I can't find screw in insert nuts short enough to not breach the surface of the panel except out of the UK.  I live in the US, I'm not paying for nor waiting on shipping out of the UK....
Anyone have any suggestions on alternative mounting arrangements or know of somewhere I can find hex drive screw in insert nuts under 1/2" long?
JDFan
Re: CP build question - mounting joysticks
« Reply #1 on: October 13, 2013, 10:09:14 am »
rhys
« Reply #2 on: October 13, 2013, 10:33:03 am »
I need non-flanged screw in.  Press-ins are for hardwood.  Screw-ins are for softwood and composites.
JDFan
« Reply #3 on: October 13, 2013, 11:00:33 am »
E-Z Lok (located in Gardena CA) makes many kinds -- http://www.ezlok.com/InsertsWood/index.html they should have a list of distributors near you.
rhys
« Reply #4 on: October 13, 2013, 05:32:46 pm »
EZ-LOK doesn't make a #10-24 or M6 shorter than a half inch either....
I can't find the #10-24's at 3/8" long on Ebay out of Hong Kong, or M6x10mm from the UK which would work as well, but I can't seem to find either size available from a US retailer  :banghead:
JDFan
« Reply #5 on: October 13, 2013, 05:36:31 pm »
Since you're putting an overlay on it anyway could you countersink the bolt heads and then cover with wood putty and sand down ?
rhys
« Reply #6 on: October 13, 2013, 07:51:19 pm »
Duhhh, hadn't thought of that.  Or I could pocket sink T-nuts and top fill with wood putty.
Thank you, I think I'll go with one of those options.  I think I like the T-nuts better so if I want to swap out sticks, I don't have to worry about the bolts breaking the wood putty when I go to loosen the nuts.
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #7 on: October 15, 2013, 03:55:54 pm »
I'm always a big fan of T-Bolts as they are super strong when applied through wood.  You can use a router and route 1/8" so the T-Bolt sits flush with the rest of the wood and then putty it in (Just like @JDFan said)
