Author Topic: Marquee light and Power switch wiring  (Read 5358 times)
thehammer12
  • Last login:October 24, 2021, 01:46:34 pm
  • Arcade Breaking Specialist
« on: October 07, 2013, 04:31:37 pm »
Im building my first arcade from scratch and Im trying to salvage what ever parts I can from this cabinet that I got a sweet deal on, as you can see in the pic (a little bit) the marquee light is tied into the power switch with a connecter and then the power switch has its owner connector at the bottom which Im guessing goes to a board or some other connector.....etc.
If I want to save this do I strip or take off he wires from the power switch and just tie it into the jamma connector/power supply directly? Also, do I do the same as well to the marquee light?
Im trying to go off the jamma wiring diagram but it doesnt say anything about using or not using connectors
 :dizzy:
« Last Edit: October 07, 2013, 04:33:20 pm by thehammer12 »
BobA
  • What Me Worry?
Re: Marquee light and Power switch wiring
« Reply #1 on: October 07, 2013, 11:22:33 pm »
Your marquee light looks like a standard 120V flourescent with starter.  It connects to AC not the jamma harness.
thehammer12
« Reply #2 on: October 10, 2013, 05:43:28 am »
So I should leave it tied into the power (switch)? Its tied in to the wires via connector about 7-8 inches down from the switch which is not visible in the photo but it is connected.
BobA
  • What Me Worry?
« Reply #3 on: October 10, 2013, 06:18:29 pm »
Yes a standard florescent light gets its power from the main power in the cab.
thehammer12
« Reply #4 on: October 11, 2013, 09:37:59 pm »
Ok thanks, If you also dont mind Im gonna post a pic of it and maybe you can tell me if it looks right.
ed12
« Reply #5 on: October 11, 2013, 09:46:27 pm »
never never ever tie a/c into the jamma harness
of course unless u want a alot of smoke and a ball of fire
jamma is low voltage olny 5/12/gnd some times -12/5
your ac is tied to the switch then the marquie light and and the monitor and power-supply for the game
if u are using a putter then the ac for it also
but never never to the jamma
ed
thehammer12
« Reply #6 on: October 12, 2013, 07:08:27 pm »
ed
Got it, Ok so here is a pic of the marquee tied in to the power switch, at the end of the wires there is another connector/s......Im assuming I strip that connect off and tie it into the filter......right?
Also Im not sure why there is 3 connectors?
ed12
« Reply #7 on: October 12, 2013, 08:32:16 pm »
live=black
return-nuteral=white
ground=green
some times u will see branch circuits on the ac
from what i can see the 2 prong plug with the green going to a eye lug was for a wellsgrander style monitor
ed
thehammer12
« Reply #8 on: October 13, 2013, 01:29:42 pm »
live=black
ground=green
ed
Wow I feel dumb, it all makes much sense now.  ok so I can lose that eye lug connector and match it to what ever I have on my current monitor, correct?  Or should I just lose it.
ed12
« Reply #9 on: October 13, 2013, 01:32:45 pm »
just depends on your setup
some times i take it off
some times i use it
just depends
just rem..it is earth ground
ed
thehammer12
« Reply #10 on: October 14, 2013, 04:55:03 pm »
I ended up saving and tweaking it to work with my monitor......got power woo hoo.
