Author Topic: Atari Missle Command Optical boards  (Read 1783 times)
MinerAl
  • Last login:December 15, 2025, 06:28:31 pm
  • duck
« on: November 19, 2003, 10:33:03 am »
Got some new optics for my giant atari trackballs.
I can probably figure it out myself without too much problem, but does anyone know off the top of his head which of the 4 pins is which?  (X1,X2,+5V,GND)
Thanks.
Al
aricade
  • Last login:August 15, 2004, 01:38:26 pm
  • Wamma langa ding dong!
    • Isaacade
Re:Atari Missle Command Optical boards
« Reply #1 on: November 19, 2003, 10:51:49 am »
would they be similar to happ/atari optic boards
if so check this out
http://www.mameworld.net/massive/How-to/Trackball_Hack/trackball_hack.html
Or
http://www.ultimarc.com/optipac4.html
I think they all sorta follow the same pinout...
hope this helps...
Off all the things I've lost I miss my mind the most!!
aricade
    • Isaacade
« Reply #2 on: November 19, 2003, 10:57:59 am »
Also see if pin 1 is clearly marked on the pcb
This will help you determine what is what...
MinerAl
  • duck
« Reply #3 on: November 26, 2003, 12:48:46 am »
I still haven't tried too hard to trace the traces on these boards yet...
For what it's worth, Missle Command optic boards, which are markedly different in layout from the original Atari Football optic boards (4 little friendly pins instead of the 1" square molex 10 pin/socket monsters), fit the mounts and encoder wheels of my AF trackball perfectly.  I'm anxious to have some time this week to finally attach them to my Opti-PAC.
If these work as well as I think they will I will replace the originals that I have working on the player 1 trackball with these smaller optic boards, simply to make room in my cabinet for other controls!
