Author Topic: Source for 5v "Angel Eyes" LED's?  (Read 2244 times)
fatsgt
  • Last login:June 29, 2015, 12:22:01 am
  • Taito Type X, I hate you.
« on: October 02, 2013, 12:05:32 pm »
I'm looking to add Angel Eyes-type led's around my Joysticks and spinner.  All the ones I've found so far are for 12 Volt connections.  I'm looking for 5v versions that I can hook-up to my PacLED64 for use with LEDBlinky.  Anyone know where I might get some?
  • Last login:Yesterday at 08:16:02 am
Re: Source for 5v "Angel Eyes" LED's?
« Reply #1 on: October 02, 2013, 12:27:20 pm »
I always run 12v LED buttons off 5v from USB -- less current draw and they look as bright IMHO.  YMMV.
fatsgt
« Reply #2 on: October 02, 2013, 12:40:16 pm »
Good to know!  They're are some pretty cheap options.  I may give em a try.  RGB would probably the way I want to go.
keilmillerjr
  • Web Developer.
« Reply #3 on: October 02, 2013, 12:54:08 pm »
It's easy enough to make them. I made a set for one of my cars one time.
You might want to look in the for sale section at the neph rings. Not exactly an angel eye, but still really cool.
« Reply #4 on: October 02, 2013, 01:06:36 pm »
If the 12v RGBs don't work with 5v, you can also replace the current limiting resistor or wire a second resistor in parallel with the current limiting resistor to reduce the voltage drop across the resistor.
LMK if you need help calculating the proper value resistor once you get the LEDs.
fatsgt
« Reply #5 on: October 30, 2013, 04:15:08 pm »
Well, finally got my cheap 12v Angel eyes in from China.  They no worky with my 5v powered PacLED64.   :'(  Finding and changing out resistors isn't something i've done before.
keilmillerjr
  • Web Developer.
« Reply #6 on: October 30, 2013, 06:03:02 pm »
The red wire on your molex connector from power supply is 5v. Both black wires are ground. Yellow is 12v.
