Author Topic: Using XBOX 360 Pad For Racing Games?  (Read 1671 times)
lettuce
  • Make It So!
« on: September 29, 2013, 03:49:50 pm »
Is there a way to setup a 360 pad so you can use the triggers as brake and accelerator like console racing games? As if i try and configure the triggers mame See both the left and right trigger as Z Axis, so when i try and accelerate im also braking as well. Does anyone have a work around for this?
Re: Using XBOX 360 Pad For Racing Games?
« Reply #1 on: September 29, 2013, 04:17:43 pm »
In MAME's in game menu, there is an option to invert the pedals.  Sounds like one or the other need inverted.
There is usually a calibration in the game's service menu.  It's helpful to watch the input test screen in the game's service menu while you mess with the settings in the MAME menu.
Don't forget to change the deadzone in mame.ini
The default is .3 (30%)
.03 or .05 is more like it.
Also, don't ever map anything to PEDAL INC or PEDAL DEC.
Those are for if you are using buttons and don't have analog controls.
If you map an analog control to it, the game will behave the same as if using a button.
