Author Topic: Naomi Cabinet with PC switch  (Read 2116 times)
bimm25e
  • Last login:July 30, 2024, 08:44:11 am
« on: September 29, 2013, 10:59:54 am »
SO I just picked up a MvC2 cabinet running on a NAOMI with a Cart in an older Dynamo Cabinet (looks like it had SFII in it back in the day, cause it still has the kit control panel overlay)
I want to maybe put a PC in it with MAME and Im wondering :
1. if I can use the JVS/JAMMA switch to plug like a KVM into and swap between the pc and NAOMI video inputs.
2. I was wondering if there were 4 player control panels available for these games as well, I Want to say I've seen them that like sit on top of the side rails of the dynamo cab.
the cabinet now, looks the same as this > http://www.severdhed.com/images/dynamo1.JPG
3. Is there a good way to hookup the buttons so that I can use the same control panel for the PC and NAOMI without causing problems?
keilmillerjr
  • Web Developer.
Re: Naomi Cabinet with PC switch
« Reply #1 on: September 29, 2013, 11:38:21 am »
Holy ---steaming pile of meadow muffin--- that's creepy. There is a cat in your machine.
Your cab looks too small for 4-player control panel.
bimm25e
« Reply #2 on: September 29, 2013, 12:35:56 pm »
haha excellent catch but that's not MY cabinet just a picture of the same.
I was hoping there was an option to put something like this >
http://i3.photobucket.com/albums/y82/Zilarko/008-drawer.jpg
http://i3.photobucket.com/albums/y82/Zilarko/001-thecabinets.jpg
Or is there something special the cabinet would need to add the 4 player CP
Paladin
  • Mmmm llamaburgers!
« Reply #3 on: September 30, 2013, 10:47:04 am »
Not sure what you mean by 'JVS/JAMMA switch'.  You might want to read up on the NAOMI system, here's a great place to start:
http://www.sega-naomi.com/forum/viewtopic.php?t=1265
paigeoliver
  • Awesome face!
« Reply #4 on: September 30, 2013, 03:33:00 pm »
Cabinet is too small and has the wrong monitor angle for a 4 player panel. The guys on the side will have a hell of a time seeing the screen for the 5 minutes they play before the giant poking out control panel acts like a lever and flips the cabinet over onto the players.
bimm25e
« Reply #5 on: October 01, 2013, 01:53:07 pm »
I guess i meant the Capcom I/O,  would I be able to hook up a PC through the VGA port using like a KVM?
Aand if that works and the video display is my PC, could I piggyback on the CP buttons wth a ps2 adapter without causing problems?
My goal would be to have a KVM swap between the NAOMI and a PC running MAME in the cabinet while using the same buttons on the control panel for both.
