Author Topic: mame and display issue?  (Read 3441 times)
pbGames
  • Last login:November 27, 2013, 08:45:55 am
« on: September 22, 2013, 07:17:01 am »
Hi,
  I am currently trying to convert an arcade machine into a mame.  I have a dual core pc and running windows xp.  I have a monitor connected to the pc via the motherboards VGA. I have downloaded mame 150 and when I run it from the command prrompt I get the following message.  Is this because I am using the motherboard driver?
C:\MAME>mame
Proposed video mode not supported on device \\.\DISPLAY1
Exception at EIP=014782C6 (drawd3d_window_init(win_window_info*)+0x01b6): ACCESS
 VIOLATION
While attempting to read memory at 00000080
EAX=00000000 EBX=0029DEC8 ECX=7C91056D EDX=00340000
ESI=77D4C78E EDI=00000001 EBP=05F5FE70 ESP=05F5FE08
Stack crawl:
  05F5FE70: 014782C6 (drawd3d_window_init(win_window_info*)+0x01b6)
  05F5FF20: 014516D9 (complete_create(win_window_info*)+0x0269)
  05F5FF80: 01451AD7 (thread_entry(void*)@4+0x0287)
  05F5FFB4: 77C3A3B0 (endthreadex+0x00a9)
  05F5FFEC: 7C80B50B (GetModuleFileNameA+0x01b4)
pbGames
Re: mame and display issue?
« Reply #1 on: September 22, 2013, 10:19:02 am »
Can somebody help out with this?
Haze
    • MAME Development Blog
« Reply #2 on: September 22, 2013, 10:34:41 am »
yes, it looks like DirectX is failing to start up, so either you don't have the current DX installed, or your drivers / video card are inadequate.
this should probably be handled a bit more cleanly in MAME.
pbGames
« Reply #3 on: September 22, 2013, 11:40:55 am »
Installing the chipset drivers and direct x has done the trick.
Thanks  :applaud: :applaud: :applaud: :applaud:
