Author Topic: How would YOU set up this system? (to jpac or not to jpac)  (Read 1792 times)
mushmouth
  • Last login:November 18, 2009, 02:26:43 am
  • Old School, baby.
« on: November 18, 2003, 04:07:35 pm »
I have a dilemma which I talked about in a thread called "Should I have bought a jpac?". Essentially, I was going to build from scratch. Ordered the ipac and optipac, and THEN found a cab with a jamma harness inside. My questions was, do I send back the ipac and get the jpac? or is that not necessary? WHAT SHOULD I DO??
So I've decided to lay my stuff out in front of you, have you look at the list, and tell me how YOU would set up this mame system using what I have (or if you'd use the jpac, say so) as well as what else I need to/should buy. My head is spinning. I need some advice...
This cab is built to play the old-school classics. Pre-'88 games, with the exception of Golden Tee.
Here's what I have:
Midway Pac jamma cab converted to Kageki (no board), with the jamma wiring harness and power supply still there. There is a 19" arcade monitor in it, but it has some burn in, don't know if I'll keep it.
Computer:
Pentium III 450mhz board, 328meg RAM
Diamond Viper video card (RIVA (sp?) TNT chip)
Power supply
Want to run under Windows 98se
1 i-pac usb (hasn't arrived yet, will return if j-pac is better option for my situation.)
1 opti-pac usb
3 swappable control panels:
1) Trackball, 5 buttons, 2 start buttons
2) Spinner, fire-top stick, 3 buttons, 2 start buttons
3) Joystick, 5 buttons, 2 start buttons
--Essentially, I'm not locked into a monitor type at this point. Have to buy something either way, so I'll take suggestions considering the setup). Flexibility for a future change of mind in monitor choices should be factored in.
Do I need an arcadeVGA card to run an arcade monitor? If yes, do I need an arcade VGA card if I have a jpac, or just with an ipac? Andy said something about being limited to DOS and Advanced MAME without an ArcadeVGA card... Like I said I'm confused...
I think that's everything. What do you think? What would you use and how would you do it, considering all this?
It ain't easy bein' Greazy.
Mugzilla
  • Last login:May 23, 2020, 03:25:47 pm
  • Negative Ghost Rider,...
Re:How would YOU set up this system? (to jpac or not to jpac)
« Reply #1 on: November 18, 2003, 04:31:09 pm »
If I had it to do over again, I would use any JAMMA and a real monitor...
My TV is nice, but I wanted authentic graphics/looks/screen flicker/etc.
My TV makes games look too nice...
pointdablame
  • Last login:April 01, 2026, 10:20:52 pm
« Reply #2 on: November 18, 2003, 04:58:44 pm »
I too was originally gonna build, and then found a working Xmen cab.  I was still set in my mind to got the Ipac/Optipac route, but I think the Jpac is now the better choice. You can still get the same outcome and can use JAMMA boards if you want to.
I think the Jpac may have fewer inputs, but I could be wrong. Either way, I'd recommend going the Jpac/Optipac/ArcadeVGA route.
The ArcadeVGA is supposedly THE card to get, I don't think I've ever seen a true complaint over one.
first off your and idiot
mushmouth
  • Old School, baby.
« Reply #3 on: November 18, 2003, 05:19:38 pm »
Pointdablame,
Take a look at my list above for my 3 different CPs. Look at each one, since I'll only be using one at a time. Will I have enough inputs with the jpac/optipac/arcadevga setup you suggest?
tmasman
  • Last login:January 04, 2024, 03:50:44 pm
  • Hello...
    • My (no so up to date) Home
« Reply #4 on: November 18, 2003, 05:38:26 pm »
Pointdablame,
The J-PAC has 28 inputs... (like the IPAC)
So you wouldn't have any problems with your set-up. (same as 2 player IPAC)
You really should check out The J-PAC page on Andy's site...
It's programmable too (Just like the IPAC)
You would still need a video card that will output 15Khz... The ArcadeVGA or there's also a Trident Video card that some one has written alternate drivers for that will work... (Search google.com, or ask around)
I'm not a freak!...
Oh wait...
Yes I am...
