Author Topic: Should I remove the 4-way from my frankenpanel?  (Read 1858 times)
Donger
  • Last login:July 04, 2004, 08:10:24 pm
  • Considduh dat a di-vorsss!
« on: November 18, 2003, 04:00:27 pm »
Hello-
Due to time/monetary/budget contstraints, I've decided that it isn't feasible for me to create the desired swappable control panels.  Thus I'm faced with decisions on what controls to include in my 4 player Frankenpanel.
One major decision I'm faced with is whether I should eliminate the 4 way joystick from my plans.  CP real estate is obviously at a premium, so I need some opinions on this subject.  How well do the normal Happ Competition or Perfect 360 joysticks work with the old classic games?  Notably, pacman, galaga, etc...Is there a huge difference?
For those of you with a Frankenpanel, do the joysticks in the front interfere with your 'inner' set of controls and your gameplay?
Thanks in advance!
Donger
SpamMe
  • Last login:July 01, 2006, 03:19:58 am
  • .creature of bad habit.
    • Mame cabinet blog
Re:Should I remove the 4-way from my frankenpanel?
« Reply #1 on: November 18, 2003, 04:19:33 pm »
I had the same problem and decided the T-Stiks (switch to change from 4way to 8way) were a good compromise between control panel real-estate, and wanting absolutely every control ever made on my panel. It seemed like a small decision at the time, but I really am glad I didn't add a lot of controls to the panel so that I could play 1 or 2 more games (that i probably don't like anyway, frankly). I love having a little extra space, and not bonking into controls
Trackball and missing button have since been installed, btw, and I do plan on adding a spinner some time.
« Last Edit: January 19, 2004, 05:02:18 pm by SpamMe »
TalkingOctopus
    • My Arcade
« Reply #2 on: November 18, 2003, 06:27:55 pm »
I have 2 Happ P360's and a trackball on my panel.  While the P360's play the classics ok, they take some getting used to.  I really miss the 4  way joystick and would recommend that you find a spot for it.
hooded_paladin
  • Last login:November 06, 2013, 08:59:01 pm
  • Finch! hahaha
« Reply #3 on: November 18, 2003, 09:44:59 pm »
why not use joystick restrictors from OSCAR to make your 8-ways into 4-ways when you need it?
There is SO a spoon.
Hammerbot
  • Last login:September 04, 2005, 10:40:51 am
  • All work and no play...
« Reply #4 on: November 19, 2003, 09:33:16 am »
Unless you are really constrained on space, work the 4-way in.
Nothing pisses me off more than getting to the top of the screen in Donkey Kong on the mud pie level and getting whacked by a fire ball because I was playing an 8 way joystick that caused me to get stuck on a ladder.
They were meant to be played with a 4-way.
I wouldn't want to deal with rotating the plate on the back of my joysticks everytime I wanted to switch between games.  Takes the flow away from the "Hey, lets play Frogger right after this X-men game" idea.
BLACK KNIGHT
  • Last login:March 09, 2019, 08:02:19 pm
  • I'm a llama! A what?!
    • Mike's X-Arcade
« Reply #5 on: November 19, 2003, 10:28:46 am »
Actually I was thinking of swapping out one of my joysticks in my X-arcade for a Ultimarc T-stick...as I understand it you can just reach under the control panel and flick a button to change from 8-way to 4-way.  Since I have a slideout keyboard drawer under my controller it should be easy to reach under to switch it over
Spaced Invader
  • Last login:July 15, 2008, 07:27:49 am
  • Resistance is... probably a good idea.
« Reply #6 on: November 19, 2003, 12:23:46 pm »
« Last Edit: November 19, 2003, 12:24:19 pm by Spaced Invader »
All Your Base Are Belong To Us!
