Author Topic: Couple questions on the PacLED64  (Read 1721 times)
fatsgt
  • Last login:June 29, 2015, 12:22:01 am
  • Taito Type X, I hate you.
« on: September 19, 2013, 03:53:18 pm »
I recently bought a PacLED64 with both Ultimarc RGB buttons and single color buttons and I have a couple questions.
1. Does this need to be connected to both a USB port and the computer via the Molex connector or just one of the two?  I'm assuming both.  If so,
2. Is anyone using any options to connect power to the unit via an external supply?  I'm assuming if you have one with with correct voltage it would be possible.
3. I didn't order the Extension Harness Pack to connect the wires to the board but it looks like I'm going to go back an order them. How do those connect to the PadLED64 Board? Do they have some sort of hollow end on the wire?
Thanks folks!
Re: Couple questions on the PacLED64
« Reply #1 on: September 19, 2013, 08:12:55 pm »
1 - Yes
2 - Yes
3 - Yes
