Author Topic: How do Tron handles fasten together?  (Read 1223 times)
soslo
  • Last login:March 10, 2012, 03:23:36 pm
  • The Governator
    • My website does not have a name yet
« on: November 17, 2003, 11:29:43 pm »
I have the screws for the top of the handle, but what about the 2 holes in the lower handle?
I am trying to secure the handles to a heavily reworked Happ Super lever...but I am thinking that I will need to make a custom hollow lever of some sort. Any suggestions?
5 MAME cabs and counting...
Ever wonder what full side art looks like?
http://www.aaronmurray.com
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
Re:How do Tron handles fasten together?
« Reply #1 on: November 18, 2003, 07:45:11 am »
The bottom parts of the handle screw right into the metal shaft of the original joystick.  Prevents twisting.
Maybe you can hack the one from happ controls?  Or find a shaft the same diameter and drill some holes in it to match.
soslo
  • The Governator
« Reply #2 on: November 18, 2003, 10:07:37 am »
I'm going to OSH after work to look for the hollow shaft.
The artwork looks awesome BTW...I've been waiting to post until I get the pics developed... ;)
rdagger
« Reply #3 on: November 18, 2003, 11:49:40 pm »
The handles can be mounted to any pipe that is about 7/8" in diameter.  I was inspired by 1up and made a Tron joystick using the plastic sides, a perfect 360 and a 1/2 PVC pipe.  PVC is great because it is very easy to tap out the holes for the metric security socket cap bolts that are typically used.  I made the PVC version as a template and had planned on building the final version with metal conduit;  however, the PVC worked so well that metal was not necessary.
soslo
  • The Governator
« Reply #4 on: November 19, 2003, 10:30:25 am »
Well, I found some galvanized pipe that is the same OD as a Happ Super js. Its acutally a hollow nipple, so on one end I put a coupling 1/4 to 1/2 inch coupler on it and it fits in the bottom of the Tron handle.
I used a 1/2" sprinkler riser (1up mentioned this I think) on the inside. I'm still working on it, but I think this will work perfectly...after some modification of course  ;)
soslo
  • The Governator
« Reply #5 on: December 05, 2003, 03:49:08 pm »
well, here is how I did it:
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=13908
turned out nice IMO - very sturdy
