Author Topic: Highscore to .txt converter?  (Read 2147 times)
icecube45
  • Last login:April 16, 2016, 02:09:11 am
  • 42
« on: August 27, 2013, 08:49:16 pm »
Hello!
I have decided to try to make an online scoreboard for certain mame games.
My problem is that I need the data in a txt file rather than a .hi file
I have found http://forum.arcadecontrols.com/index.php?topic=83614.0
But the problem is is that It only shows the output, and does not write it anywhere.
As well as it doesn't seem to be able to run via command line, is only command line based.
Also, it cannot convert mass files
I guess what I'm really asking is,
does anyone know of/can modify HitoTxt so that it can process multiple files via a command or simple .exe (So I could run it at startup) and save the files as txts somewhere?
I know it may be a lot, but I would be eternally grateful
-ice
I'll make sure to report back!
dna disturber
  • Last login:August 03, 2014, 01:01:22 pm
  • Michael J. was my 1st experiment,cut me some slack
    • Cabinet "Monster Arcade" & Bartop "Futurama"
Re: Highscore to .txt converter?
« Reply #1 on: August 28, 2013, 06:24:26 am »
You can use stdout from the commandline.
Use the hitotext command and put >>hiscore.txt behind it (you can put in another directory or any name that you want)
You can even make a batchfile so that you can do it for all .hi that you have
Hitotext can be used using the commandline btw.
« Last Edit: August 28, 2013, 06:27:05 am by dna disturber »
Author of PINemHi..
Decipher-dude for the HiToText project..
HiToText 2010.11.4  Vs.  Mame 0.140  ::)
Percentage of original games in HiToText :  8.09 %
Percentage of original + clone games in HiToText : 10.57 %
icecube45
  • 42
« Reply #2 on: August 28, 2013, 05:52:38 pm »
Thanks for clarifying that, I will test something out asap
