Author Topic: Computer Problems  (Read 2073 times)
Elemental
  • Last login:November 12, 2003, 09:51:41 pm
Computer Problems
« on: November 16, 2003, 12:51:41 pm »
I am having some problems with my computer that I was going to use in my cab. It is a 2.0ghz Intel Celeron with 256mb of DDR ram on a p4s533 motherboard and a Radeon 9200. I was expecting this to run all the mame games I play, but it seems that it wont. When I try to play Area 51, its is very slow. Is this my CPU, Video Card, or my RAM? I hope it is ram, cause i dont want to have to buy a new cpu! Thanks!
TalkingOctopus
    • My Arcade
Re:Computer Problems
« Reply #1 on: November 16, 2003, 03:43:52 pm »
It is probably your CPU.  But try messing around with all of the mame settings to make it faster before you buy anything new.
« Last Edit: November 16, 2003, 03:44:32 pm by TalkingOctopus »
BarontheFirst
  • Last login:April 11, 2023, 07:42:07 pm
  • Locked out of the gameroom again!
Your RAM needs to be increased!
« Reply #2 on: November 16, 2003, 09:51:23 pm »
On my Athlon XP 1800+ 1.53ghz and 512DDR Area 51 runs at full speed. To be honest I never did like Celeron processors and it might be part of your problem. Still first I recommend you increase your ram to atleast 512mbs. If that doesn't fix it then it could very well be the cpu.
Elemental
« Reply #3 on: November 16, 2003, 11:51:04 pm »
Thanks for the replies.
I never like the celeron much myself, but I had the motherboard, and the price was right. I will try to get 256mb more ram (seems to be cheap these days) and then if that doesnt work I will just overclock the CPU a bit. I bet I could get it to 2.4 with the stock HSF, but thats for another discussion   ;D
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #4 on: November 17, 2003, 11:13:03 am »
Your best bet would be to replace the celeron with the pentium (whichever one fits the socket).
Elemental
« Reply #5 on: November 17, 2003, 02:18:52 pm »
I will pull the RAM out of my main PC and see if the ram is the problem, and if that runs smooth I will add more ram. If it is not, I will overclock it about 400mhz and see if that helps. I will report whatever helps on this thread! And JustMichael, I would rather not spend the money on the pentium 4 proc, this celeron was a steal!
MUKid
  • Last login:March 31, 2004, 12:23:35 am
  • Hoody Hoo!
« Reply #6 on: November 17, 2003, 04:12:58 pm »
I've heard that the lack of L2 Cache on the Celeron causes big speed issues in MAME.  MAME is very memory-dependent, so apparently RAM and cache are the most important things.  This is just what I've been told -- in fact, I bought a Thunderbird instead of a Duron for just that reason.
Spaced Invader
  • Last login:July 15, 2008, 07:27:49 am
  • Resistance is... probably a good idea.
« Reply #7 on: November 17, 2003, 09:13:36 pm »
Interesting reading...notice the wide differences in cache sizes.
http://www.geek.com/procspec/procspec.htm
All Your Base Are Belong To Us!
MUKid
  • Hoody Hoo!
« Reply #8 on: November 17, 2003, 11:10:17 pm »
Cool site.  It's hard to keep up with all the CPUs unless you're buying them every few months, which I'm not.  Palomino, Hammer, Celeron, Opteron, I get so confused!
