Author Topic: AHK help needed please  (Read 2590 times)
Connorsdad
  • Last login:May 18, 2024, 04:28:42 pm
« on: August 07, 2013, 05:06:19 pm »
I have 8 Ahk.exes loading at startup of windows, each one has a custom loop consisting of:
Code: [Select]
Loop
Process, Wait, process.exe
run blah blah
Process,WaitClose, process.exe
run blah blah
So Ahk_process1.exe would have:
Code: [Select]
Loop
Process, Wait, process1.exe
run blah blah
Process,WaitClose, process1.exe
run blah blah
Ahk_process2.exe would have:
Code: [Select]
Loop
Process, Wait, process2.exe
run blah blah
Process,WaitClose, process2.exe
run blah blah
etc etc etc
How do I combine these into one ahk?
« Last Edit: August 07, 2013, 05:13:16 pm by Connorsdad »
keilmillerjr
  • Web Developer.
Re: AHK help needed please
« Reply #1 on: August 10, 2013, 04:27:53 am »
You can combine them, but autohotkey does not support multi-threading. It runs code one line at at time.
Connorsdad
« Reply #2 on: August 10, 2013, 07:39:48 am »
Only one of the processes will be active at any one time therefore only one loop will be active at any one time. How do I have all the loops in one ahk script?
Sent from Amstrad CPC464
Connorsdad
« Reply #3 on: August 10, 2013, 10:24:06 am »
Sussed it :)
Edit:
No I haven't :(
« Last Edit: August 10, 2013, 10:35:51 am by Connorsdad »
nitz
  • Last login:November 24, 2015, 07:57:29 pm
« Reply #4 on: August 11, 2013, 12:56:11 am »
Only one of the processes will be active at any one time...
If that's the case, I'm thinking something like this could work:
Code: [Select]
Loop
Process, Wait, process1.exe, 0.1
If (ErrorLevel != 0)
run blah blah
run blah blah
Process, Wait, process2.exe, 0.1
run blah blah
run blah blah
Process, Wait, process3.exe, 0.1
run blah blah
Process,WaitClose, process3.exe
run blah blah
Connorsdad
« Reply #5 on: August 11, 2013, 09:16:31 am »
Thank you nitz, absolute star :)
Much tidier now.
nitz
« Reply #6 on: August 11, 2013, 04:46:38 pm »
Glad it worked for you.
