Author Topic: New guy here from Belgium  (Read 1290 times)
Bensrestorations
  • Last login:June 18, 2014, 04:40:58 pm
« on: August 07, 2013, 09:19:52 am »
Hi every one, My name is Ben and my dream is to build an arcade cabinet, that will run on the ps3. And as template on the outside :notworthy: iron maiden.
Are there members here that having a ps3 cabinet project?
sorry for my bad english,but i do my best.
Greetings Ben ;)
Re: New guy here from Belgium
« Reply #1 on: August 07, 2013, 09:46:43 am »
Welcome!  :cheers:
Martijn's Marvel Vs Capcom ran a PS3 and is a beautiful design.
EDIT: looking at the thread again, he switched to a jtagged xbox360
http://forum.arcadecontrols.com/index.php/topic,112721.0.html
The 32" screen would be too big for my taste.
I have a 27" screen about the same distance away and I wouldn't want it any bigger.
Other people don't have a problem being close to a big screen, so it's your call.
If possible, do a test setup on top a table to see if you're ok being that close.
Consider using seimitsu buttons with PS3 labels on the inserts.
Here are the xbox ones I did and a template/instructions to make your own,
http://forum.arcadecontrols.com/index.php/topic,128941.msg1324181.html#msg1324181
« Last Edit: August 07, 2013, 10:05:29 am by BadMouth »
Bensrestorations
« Reply #2 on: August 07, 2013, 02:08:18 pm »
Hey nice to meet you,
yeah 32" is to big like you said. i preferer 27" to.
i'm totally new in this world so i have to start from zero :-)
I have some experience in restorations like this:
Hey your projects are really awesome Badmouth, im a big fan of your work :notworthy:
Brian74
  • Yep... I built that!!
« Reply #3 on: August 07, 2013, 02:10:43 pm »
I will be running a PS3, xbox 360 and PC all in the same cabinet. I have two ps360+'s and a four port kvm switch. I could run a dreamcast, but my PC runs the emulator fine.
Sent from my SGH-T989 using Tapatalk 2
« Last Edit: August 07, 2013, 02:14:11 pm by Brian74 »
Bensrestorations
« Reply #4 on: August 07, 2013, 04:04:57 pm »
Hi Brian, maybe in the future i buy a xbox, i'm not so good in electronic. Step by step, your arcade cabinet must be a muscle cabinet  ;D
