Author Topic: MameWah system.zip files won't install  (Read 6455 times)
ThePie
  • Newbie
  • Last login:August 06, 2013, 04:10:21 pm
« on: July 28, 2013, 05:57:21 pm »
Just a FYI I'm new here and not sure if this is the right spot to post this...
I'm trying to use MameWah and the system files (system.zip) won't install. I unzip the files into a folder called system on the desktop. Then run setup.bat. But all the command line's fail to install there file. I'm on Win 7 32 bit. I've also done this on a fresh copy of Win XP Pro and that installed fine but my question for that one is everytime I run mamewah.exe its really slow and laggy.
This is the mamewah.txt that's in the main mamewah folder (log file im guessing)
Code: [Select]
7/28/2013 4:41:32 PM MAMEWAH v1.69 launched
7/28/2013 4:41:32 PM Missing system file: C:\Windows\system32\paintx.dll
7/28/2013 4:41:32 PM Missing system file: C:\Windows\system32\mscomm32.ocx
7/28/2013 4:41:32 PM System files missing, MAMEWAH quit.
« Last Edit: July 28, 2013, 06:01:39 pm by ThePie »
jelwell
  • Last login:December 24, 2014, 03:47:21 pm
Re: MameWah system.zip files won't install
« Reply #1 on: July 28, 2013, 10:19:45 pm »
