Author Topic: Problem mounting PC CRT in cabinet  (Read 1335 times)
iscariot
  • Last login:April 02, 2025, 12:44:33 am
« on: July 24, 2013, 09:22:26 am »
He everyone.  I am having a little trouble mounting a PC crt and I hope someone can help.
I mounted the tube quite easily, but when I went to put the monitor back together in there(the boards) I think I got everything however I get no picture.  Everything looks like it's plugged in correctly.  I hear the degaussing coil go off, and there looks like there's a little bit of lightning on the screen for a second then it goes black and the input flashes like there's no connection.  Has anyone ever seen something like this?
UFO
  • Last login:July 31, 2025, 01:00:25 pm
  • Im nearly out of unproductive things to do at work
Re: Problem mounting PC CRT in cabinet
« Reply #1 on: July 24, 2013, 12:07:42 pm »
I know nothing about this, and my only knowledge would be the refresh rate... Is that an option?
Pictures of the back might also help some of the more techi / electronic chaps here...
iscariot
« Reply #2 on: July 24, 2013, 02:05:44 pm »
I don't think that is it...I had a board plugged in before and it was running fine when it was in it's case..I'm going to try disassembling some things to move the boards around a little and see if maybe something is disconnected.
iscariot
« Reply #3 on: July 25, 2013, 01:44:15 pm »
Fixed it.  Loose wire.
