Author Topic: how to install cpu on showcase 33 arcade (jamma)  (Read 2697 times)
Caparo8bit
  • Last login:April 28, 2018, 02:13:32 am
  • Hyperspin/Maximus
« on: July 22, 2013, 02:58:18 am »
hello guys i just bought a showcase arcade 33 deluxe and i wld like to install my cpu(with maximus arcade) and b able to use the buttons and joysticks ' the question is how???? this is a original arcade using jamma harness..more inf:
monitor : hantarex monitor polo 33"
-mains input:            80-130 v  a.c. 60 hz
-video input signal : rgb positive
-video bandwidth :   15 mhz -3b
-sync inputs : horizontal and vertical , positive and negative,
-horizontal and vertical scanning frequencies : horizontal 15,700 +- 500 hz ajustable. vertical 45-65 hz ajustable.
 thanks for your help
Endprodukt
  • Last login:September 08, 2026, 05:50:12 am
AW: how to install cpu on showcase 33 arcade (jamma)
« Reply #1 on: July 22, 2013, 03:09:51 am »
Jpac from ultimarc.
Caparo8bit
  • Hyperspin/Maximus
Re: how to install cpu on showcase 33 arcade (jamma)
« Reply #2 on: July 22, 2013, 08:16:33 pm »
« Last Edit: July 22, 2013, 08:35:44 pm by Caparo8bit »
BobA
  • What Me Worry?
« Reply #3 on: July 23, 2013, 01:06:26 am »
Jpac is jamma plugable.  The x arcade adapter is just an interface like the ipac, keywiz, and many others.  You are comparing apples to oranges.  The conversion of a jamma cab for use with a pc is exactly what the jpac was designed for.
Caparo8bit
  • Hyperspin/Maximus
« Reply #4 on: July 23, 2013, 01:27:10 am »
Thanks...im getting the j pac.....so just plug and play?
  • Last login:Today at 03:24:10 am
« Reply #5 on: July 23, 2013, 05:51:01 am »
Unless the monitor in your cabinet is tri-sync or high res, you will need to configure your PC to output arcade resolutions or you won't get a picture or even worse - break your monitor.
