Author Topic: Speaker wiring to jack - diagram confirmation needed.  (Read 2161 times)
UFO
  • Last login:July 31, 2025, 01:00:25 pm
  • Im nearly out of unproductive things to do at work
« on: July 19, 2013, 06:35:10 am »
Hi All,
Can you confirm the wiring for the below diagram?
Not looking to do anything like re-invent the wheel -- I figured that stereo would not be needed for the cab, hence the mono jack.
Thanks chaps
EssJay
JDFan
Re: Speaker wiring to jack - diagram confirmation needed.
« Reply #1 on: July 19, 2013, 11:09:43 am »
That would be correct if you are wiring them in series -- if wanting them wired in parallel you would run one wire to both speaker grounds and the other wire to both speaker positive terminals. Here is an article which discusses the 2 methods and reasons for chosing one vs. the other - ( http://www.termpro.com/asp/pubs.asp?ID=124 )
UFO
« Reply #2 on: July 19, 2013, 03:32:52 pm »
Thanks JDFan,
That is a pretty comprehensive explanation!
Both speakers I have already have the right relevant electronics attached to them, so I don't really need to worry there.
From what I read, the only difference between wiring win parallel and serial is the addition of speakers - would that be correct? I'm not planning on adding any more to the two...
JDFan
« Reply #3 on: July 19, 2013, 07:51:15 pm »
Actually there is some other differences -- Here is a good video explanation ( )  that should clarify and suggest why for the 2 speakers you'd be better off using a parallel wiring scheme. (It's about 8 minutes long but the 2:30 mark is where the relevant info starts )
ie. if you wire in series the output of the speakers is cut in half with 2 speakers where in parallel each speaker still puts out full output but the amperage used increases -- with only 2 speakers the amperage will be fine but it is something to keep in mind if adding several speakers could exceed the amperage output the amplifier can handle in which case you'd want to wire some in series to avoid overloading the amplifier. (the video explains it better !)
UFO
« Reply #4 on: July 19, 2013, 08:22:42 pm »
Thanks JDF... That has helped a lot...:D
Sent from my GT-N7105 using Tapatalk 2
UFO
« Reply #5 on: July 20, 2013, 09:02:45 am »
OK... These are the speakers I have acquired.
Both have a couple of electronic components on them (impedance? / capacitor), and also a trailing wire from the "-".
One of the components is only attached to the "+", and I'm not sure where this attaches.
I have no idea what to do with this stuff - my thoughts are to strip them off and be left with just the terminals, and wire them that way.
They are not going to be powered through an amp, just plugged in to the PC.
What are your thoughts on this anyone!
Thanks again...
« Last Edit: July 20, 2013, 09:18:33 am by UFO »
UFO
« Reply #6 on: July 29, 2013, 05:52:55 pm »
Ok... just going to remove the components and keep my fingers crossed.
I figure that they may only be needed for some kind of powered speakers - I gues!! ???
