Author Topic: 4-player games on 2-player cabinet?  (Read 1746 times)
just_jeepin
  • Last login:October 28, 2020, 09:26:26 pm
« on: November 14, 2003, 01:46:15 pm »
If I build a 2-player cabinet and want to play a 4-player game (ie gauntlet, mortal kombat, etc), will there be any problems?  I'd think you would just have 2 player stats that would always say 'insert coin'.
Thanks for any info!
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:4-player games on 2-player cabinet?
« Reply #1 on: November 14, 2003, 01:53:07 pm »
that's why I have the usb ports on my cabinet, for extra gamepads.
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: November 14, 2003, 02:09:35 pm »
If I understand correctly, the question is "Can I play 4-player games, if my cabinet is only set up for 2-player games".
The answer is Yes, except you might be limited to only the first two players.  I can't think of a specific example, so I'll make stuff up :-)))
Let's say Zorgon is a 4-player game  -  It uses the credits to determine what player you will be -
Player 1 - Clyde - the red warrior
Player 2 - Pinky - the pink warrior
Player 3 - Shazaam - the blue warrior
Player 4 - Hawk - the yellow warrior
If you can't input coins for Player 3 or Player 4, you can only be Pinky or Clyde, never Shazaam or Hawk.
However, search MAME and there is probably a clone called "Zorgon (2 players)" which will probably let you move the joystick to select any of the four players after putting a coin in slot 1.
"All names have been changed to protect what's left of my memory from having to work too hard."
eightbit
  • My cab is never done...
« Reply #3 on: November 14, 2003, 11:07:16 pm »
A specific example is TMNT, though not only do you have to input  coins in slot 3 you would also have to use joystick 3 to play. There is a 2 player clone though that lets you select what character you want to play regardless of joystick.
An example of a 4 player that their is no 2 player version that I am aware of is Simpsons.
TalkingOctopus
    • My Arcade
« Reply #4 on: November 14, 2003, 11:46:11 pm »
The japanese version is 2 player and as far as I know it is almost exactly the same as the 4 player version.
