Author Topic: 8-way joysticks, OR 4-way and 8-way joysticks?  (Read 1554 times)
just_jeepin
  • Last login:October 28, 2020, 09:26:26 pm
« on: November 14, 2003, 01:42:50 pm »
I'm planning on building a cabinet (no decision on upright or cocktail yet) and was wondering if I should use 8-way joysticks, OR 4-way and 8-way joysticks?
Thanks for any help!
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
Re:8-way joysticks, OR 4-way and 8-way joysticks?
« Reply #1 on: November 14, 2003, 01:53:08 pm »
My first cab was a cocktail one, it has 3 side to it
one side has a orig pacman 4 way stick the other side has a 8 way and a trackball and then on the longer empty side I have a two play street fighter setup.  This setup allows me to get the best of all worlds!   I guess the question I would ask you is, what types of games to you plan on playing, newer or older?  The older games tend to use the 4 way sticks and the newer are mostly 8 way.
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: November 14, 2003, 01:55:26 pm »
Depends on cabinet design (CP size) and the types of games you will be playing.  Keep watching www.groovygamegear.com, and an answer may materialize in a few days (weeks?).
