Author Topic: Lexan Control Panel overlay  (Read 3311 times)
Terr1
  • Last login:September 19, 2016, 04:06:57 pm
  • Building my first cabinet
« on: July 15, 2013, 09:24:37 am »
I want to order a Lexan control panel overlay since I have to order 2 plexiglass sheets for my marquee.
What lexan thickness do you usally use? Are 2 mm lexan okay?
When I need to drill the holes (I'm planning on a control panel sandwich, drilling through my existing holes), I used a spade drill to drill my 30mm button holes. I've seen people using different techniques..
1. Frostner drill
2. Router (I don't have a router atm).
Will either do fine?
nemesismachine
  • Last login:August 18, 2014, 11:44:04 am
Re: Lexan Control Panel overlay
« Reply #1 on: July 15, 2013, 10:41:49 am »
I did mine by clamping the plexi to the CP, and drill holes in each button, then route each hole.  Way faster that way, you can zip to each button hole and do the perimeter. No need to overthink it.
« Reply #2 on: July 15, 2013, 04:49:45 pm »
I use a dremel with the lexan clamped to the CP.
selfie
« Reply #3 on: July 15, 2013, 05:14:35 pm »
There is no need to use polycarbonate(Lexan) acrylic is better suited for a CPO. I used 1.5mm Acrylic.
Read this http://forum.arcadecontrols.com/index.php/topic,119165.0.html
Terr1
« Reply #4 on: July 15, 2013, 05:45:07 pm »
Ah great.. I can get 1.5mm plexi as well.. I will go for this instead then.. And thanks for the link very informative thread :)
