Author Topic: More than one rom directory in MameWah?  (Read 1084 times)
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
« on: November 13, 2003, 12:39:29 pm »
Is it possible to use more than one rom directory in MameWah?   Can you use the Delimiter thing?
c:\mame\roms; c:\mame\roms2
TalkingOctopus
    • My Arcade
Re:More than one rom directory in MameWah?
« Reply #1 on: November 13, 2003, 01:27:36 pm »
Currently, mamewah only supports one directory.  This has been talked about alot lately. Apparently it used to support more  than one and will again in the future soon.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #2 on: November 13, 2003, 01:28:27 pm »
MinWah plans on adding it back in.  For now all you can really do is define the emulator more than once with a different folder.
creatine28
« Reply #3 on: November 13, 2003, 07:23:52 pm »
Just thinking about it and wouldn't it work to add the extra roms paths via the mame.ini file?  I'll have to give it a try.
« Reply #4 on: November 14, 2003, 05:28:06 am »
This would work for MAME itself, but not MAMEWAH (assuming you are using a 'ROM Folder' type List Generation Method).
Thinking about it also, you could have ROMs in different folders if you used the DAT File List Generation Method.  A bit of a pain perhaps to have to create the DAT file - but it would work :)
