Author Topic: G07 white screen  (Read 3754 times)
bonedoc
  • Last login:August 10, 2013, 01:18:20 am
G07 white screen
« on: June 20, 2013, 12:08:17 am »
So, I bought a mint centipede with a g07 monitor. The monitor was dead. The seller said the screen was getting more narrow over time and eventually went dead. I tested the HOT transformer, and it was dead. So, I replaced it and its fuse. This brought it back to life, sort of...
The monitor powered on and has a white line about 3" wide and it went vertical.
I then did a complete cap kit, and this fixed this issue. I now have full screen....but....
The screen is white and has some vertical lines on it. The game is playing, but the screen just shows nothing. Any ideas as to the cause?!
bonedoc
Re: G07 white screen
« Reply #1 on: June 20, 2013, 12:09:39 am »
Sorry, that pic should be rotate 90 degrees to the right.
MonMotha
« Reply #2 on: June 20, 2013, 12:51:32 am »
Turn down the "screen" control on the flyback.  Does the situation improve, or does it just go black?
bonedoc
« Reply #3 on: June 20, 2013, 09:27:31 am »
Hey there. It just goes black.
buffett
  • Last login:December 13, 2016, 01:28:10 am
« Reply #4 on: June 20, 2013, 10:08:59 am »
check R517 it may be open or way out of tolerance.
reflow all your header pins on the chassis as well.
Peace
Buffett
Come to MAGfest and game in the 24-7 arcade for 4 days. www.magfest.org  And see my collection of 90+ Arcades and growing.
Need your (K7000, 4900, std/med res 13"-25") or Sanyo fixed!!!! pm me.
Visit my website. www.thearcadebuffett.com For Monitor and PCB repairs.
Fully rebuilt chassis ready to ship. Trade'ins welcome
I have met --- Tim McVey --- world nibbler champion and many of you have not.
bonedoc
« Reply #5 on: June 20, 2013, 11:01:04 am »
Ok, I tested r517 and I am getting about 23k Ohms. Is this right?
I did reflow the headers, but I never reflowed the neck board. Maybe I should do this.
bonedoc
« Reply #6 on: June 20, 2013, 11:18:21 am »
Ok, I need to add something....
I also tested r516 and it is doing the same as r517. When I measure them, they both start out at 18k ohms and drift slowly up to 23k ohms. I find it odd that they are drifting. I made sure it wasnt a meter problem and measured a 1k 1% resistor.
I have read different values on r516 and r517, but what I have read is the 180-200k range. So, Im guessing these may both be a problem?
Does anyone know what these values are supposed to be?
What are they used for? A voltage divider?
buffett
« Reply #7 on: June 20, 2013, 11:29:50 am »
did you lift a leg and measure them out of circuit.
you need to do this with all resisters.
R517 is 180k
r516 is 150k
i do knot know what they are used for officially.
but i do know they control the screen voltage/brightness.
Peace
Buffett
bonedoc
« Reply #8 on: June 20, 2013, 11:50:46 am »
I cut a leg off each resistor and measured. R517 is 187k Ohms, and R516 is coming in at 10k Ohms.
So, 517 is good and 516 is way low. I hope this is the issue ;-) I suppose this could be why I have to turn up the brightness really high to see anything....
« Last Edit: June 20, 2013, 12:13:23 pm by bonedoc »
buffett
« Reply #9 on: June 20, 2013, 11:53:41 am »
could quit possibly be.
edit your post so the info is correct about R516.
Peace
Buffett
bonedoc
« Reply #10 on: June 20, 2013, 03:16:43 pm »
I was wrong! Both of the resistors were fine. I accidentally measured the 10k resistor next to r516. Back to square 1.....may just have to get a new monitor.
buffett
« Reply #11 on: June 20, 2013, 05:31:43 pm »
you could send in the chassis for repair.
i repair those model chassis.
visit my site and shoot me an email.
Peace
Buffett
MonMotha
« Reply #12 on: June 20, 2013, 10:53:01 pm »
Is there any color on the monitor or is it just white/gray?  It looks white to me in the picture, but I'm trying to make sure the picture isn't lying.
If it's actually one color primary, you may have a bad drive transistor.  If it's white, it's probably somewhere else.  Unfortunately, I'm not particularly familiar with the G07, but they're very common so somebody on here will probably chime in if you can get enough info to ring a bell with somebody who's seen the problem before.
Ken Layton
  • Guru
  • Technician
« Reply #13 on: June 22, 2013, 02:00:56 am »
The signal input cable is plugged in, isn't it?
