Author Topic: Rowe Ami R90 Jukebox - connecting an external audio device  (Read 15510 times)
Chalman
  • Newbie
  • Last login:June 18, 2013, 01:38:45 am
« on: June 18, 2013, 01:38:45 am »
Hi, I have a Rowe Ami R90 jukebox with pioneer CD player fitted. I want to add my Squeezebox player so it plays through the jukebox as this would give me access to my digital music through the warm sound of the jukebox. I had hoped that there would be an easy aux in point I could use but on looking at the amp (photo attached) there seems to be a plug in what is labelled as aux in/ out socket. Is the CD player connected via this socket? Can I utilise this socket even though there is an existing plug in it? Or is there a better way to connect an external device such as the Squeezebox?
Thanks for any advice that anybody can give, I know we have some Rowe Ami/ Jukebox professes signals on this forum.
Cheers
Pete
Melbourne Australia
Ken Layton
  • Guru
  • Technician
Re: Rowe Ami R90 Jukebox - connecting an external audio device
« Reply #1 on: June 18, 2013, 02:42:26 am »
Rowe makes an optional accessory circuit board that mounts on the face of the amplifier. It has a bunch of RCA jacks on it that give you access to all kinds of inputs and outputs of the amplifier.
Rowe kit # 26694703 Amplifier Accessory Board Kit, for model R-90 through CD-100-E
Here are the instructions for the kit:
http://arcarc.xmission.com/PDF_Jukebox/Rowe_AMI/Rowe_Amplifier_Accessory_Board_Kit_26694703_%28Rev_3-93%29.pdf
The kit can be purchased from any Rowe jukebox distributor's parts department or from Happ Controls. Sometimes used kits show up on ebay.
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
« Reply #2 on: June 18, 2013, 07:59:55 am »
Hello Pete,
Welcome to the forum.
Ken is correct the best way to go would be the auxillary board.
I can see that the top connection plug on the aux input/output connection is an output (more than likely to the sound to light unit) this uses pins 2 & 4 plus the ground at number 3.
I also that there is some other screened cables going below to maybe another plug underneath more than likely an input for CD with connection to pins 1 7 5 and again the common on pin 3.
Because of the length of the connection pins for the input, aux input/output and volume it could allow for more than one connector fitted, On the input & volume it was common practice to place a blank plug lower down on the connection pins to avoid shorts from screens on the upper connection plug if pushed to far down the pins.
Regards
Alan
Alan Hood
ami-man
UK
geduk
  • Last login:May 13, 2016, 03:12:36 pm
« Reply #3 on: August 01, 2013, 12:44:54 pm »
Hi Every one I have just got the very Accessory board mentioned above with the above linked instructions .. the photo at the top shows the amp I have My problem is that the instructions are not very clear
in  the step by step bit
Step
No4 .  I can work out where the 13 pin plug can goes ref ( fig 1 ref 3 )
but it says
no5 plug auxiliary interconnect Cable (fig 1 ref 4) into amp aux input
but where is that I think its the five pins in the above pic just above the 13 pins .. its the only 5 pins on the amp but what do I do with the plug that's on that already ...
then it say
6 important
the microphone interconnect cable (fig 1 - ref 5 must always be installed
do step c in no mic's are used
C says plug cable into the amps microphone input but I have no idea where that is at all Help pls
Note
My Jukebox  is the R86 and the amp model number is 6-07438-2
Ged
« Last Edit: August 01, 2013, 01:01:04 pm by geduk »
Ken Layton
  • Guru
  • Technician
« Reply #4 on: August 01, 2013, 02:11:49 pm »
Note
Ged
This kit is made for the R-90 and up.
The R-86 takes a completely different amplifier accessory board kit # 2-66974-02 instead. Sometimes it is listed as 26697402.
« Last Edit: August 01, 2013, 02:20:15 pm by Ken Layton »
geduk
« Reply #5 on: August 01, 2013, 02:47:40 pm »
Hi This board is for my machine It says so in my manual
Ken Layton
  • Guru
  • Technician
« Reply #6 on: August 01, 2013, 03:50:05 pm »
Hi Every one. I have just got the very Accessory board mentioned above with the above linked instructions .. the photo at the top shows the amp I have.
Then I'm a little confused because the picture shows 6-09931-02 amplifier.
« Last Edit: August 01, 2013, 03:51:52 pm by Ken Layton »
ami-man
« Reply #7 on: August 02, 2013, 05:47:51 am »
Hello Ged,
Are you in the UK?
If that is the case contact me by email and I will give you my details.
Regards
Alan
Alan Hood
ami-man
UK
alan-hood@datex.co.uk
MattMead
  • Newbie
  • Last login:August 14, 2014, 04:02:06 pm
« Reply #8 on: October 28, 2013, 04:13:22 pm »
I have a 6074382 amp for my R85.
I can find the accessory board 60792702 which apparently is for the r90 and up.
Does anyone know what the accessory board part number is for the r85?  I cannot seem to locate the 26697402 kit, but perhaps if I knew the actual board part number I could track that down.
Many thanks!
ami-man
« Reply #9 on: October 29, 2013, 07:02:09 am »
Hello Matt,
The listed part number for the Amplifier Accessory Kit is 2-66947-01.
I have the correct board in stock with the 3 pin auxillary connection part numbers (Rowe Ami have a habit of confusion) on the front of the board 6-07443-01 and etched on the circuit board 6-07442-01.
Regards
Alan
Alan Hood
ami-man
UK
Mitchelldeli615
  • Newbie
  • Last login:November 20, 2013, 11:50:14 am
« Reply #10 on: November 20, 2013, 11:50:14 am »
Hello, I just purchased a Rowe R-84 jukebox and am looking for the amplifier accessory kit to hook up an auxiliary input.  My amplifier # is 6-07438-2.  Can anyone help me?  Thanks a bunch!
