Author Topic: Please help me with NullDC PLEASE!!  (Read 11129 times)
Javy3
  • Last login:June 17, 2013, 09:54:24 am
« on: June 13, 2013, 10:22:58 pm »
Hello,
I have been trying to get a dreamcast emulator running on my arcade with Mala as my frontend.  I am currently trying to get NullDC up and running but so far it runs really slow for most of the games I have.  Power Stone 1 runs OK but Zombie Revenge and MvC2 run so very slow.  I heard that maybe if I use Chanka sound plugin it would run faster but I don't know what file is the Chanka sound plugin.  I did take the vmsbrowser.exe from Chanka and put it in my NullDC folder but I don't know how to enable it or if I have to do anything.  I am basically lost and confused and any help or suggestions as to how I can get a Dreamcast emulator to work, NullDC or any other would be GREATLY appreciated.  My PC specs are:
Intel pentium 4 CPU 3.0ghz
2GB ram
32 bit os
ATI Radeon Xpress 200 series, chip0x2A61
DirectX 11
Windows 7
If my PC just can't handle it please let me know.  Thank you in advance.
Peja
  • Last login:June 09, 2015, 04:48:22 pm
Re: Please help me with NullDC PLEASE!!
« Reply #1 on: June 14, 2013, 11:29:56 am »
When I started playing around with NullDC I had a hard time playing Powerstone and other games as well.  I had a quad core setup with onboard video and 4gb ram, and Win7.  I then put one of my nvidia 8800gt cards into the system and everything was just fine.  No more stuttering or lag.
I am not sure how your vid card stacks up against mine but that is what fixed it for me.  I wouldn't be surprised if you wouldn't see an improvement from more memory as well.
Now I am stuck on configuring the controllers to my control panel.  I can config player 1 but 2,3,4 won't do anything within the settings.  Also, once I close down nulldc, the settings are wiped out for player 1.  It's frustrating and I will be making a thread on it for help here in the next week or two I believe.  It's really one of the last things I need for my Hyperspin set up.
Hope you figure it out and don't have to dump too much money into it.
Peja
Javy3
« Reply #2 on: June 14, 2013, 12:24:25 pm »
Peja
Thanks for the response.  Yea I hope it's just a plugin problem because in all honesty I won't spend anymore money on the PC if it's too weak to play Dreamcast games.  I am not savvy enough to replace the vid card and I don't wanna spend anymore money on it.  It already has Mame, FBA, NES, SNES, Genesis, PSX and Megaman vs Street Fighter.  I am gonna hope that if I use an older version of NullDC, mainly v1.0 beta1.6 that it might work.  What version do you have?
Peja
« Reply #3 on: June 14, 2013, 01:49:51 pm »
I am not 100% sure but 1.6 sounds familiar to me.  I will definitely be playing around with it here in the next week or two.  I will know more then.
Of all the emulators, NullDC and Daphne have given me the most trouble.
Peja
stigzler
    • Mago Arcade
« Reply #4 on: June 15, 2013, 07:41:47 pm »
Struggling with NUllDC too. Recently replace graphics card to 1GB version - consistent framerate around 60 and gfx a lot better. But still the annoying crap with stuttering sound (not AS bad, but still enough to make it annoying). No matter how ahrd I trawl - can't seem to find the answer to this- whether it's hardware, plugins, ROMs or OS's Recently thought it was XP + DX cap on Ver 9, but another fella said he had it working fine on XP! Anywhoos, to contribute to taming this emulator, my system specs:
Mainboard :   ASRock 4Core1600-GLAN
Chipset :   Intel G31/G33/G35
Processor :   Intel Pentium XE 935 @ 3200 MHz (2 Core)
Memory :   2048  MB (2 x 1024 DDR2-SDRAM )
Video Card :   NVIDIA GeForce 9600 GT
Hard Disk :   MAXTOR STM3320820A (320GB)
Hard Disk :   Western Digital WD2500KS-00MJB0 (250GB)
CD-Rom Drive :   DTSOFT Virtual CdRom Device
Monitor Type :   BenQ BenQ 241W - 24 inches
Network Card :   Realtek Semiconductor RTL8168/8111 PCIe Gigabit Ethernet Adapter
OS :      Microsoft Windows XP Professional 5.01.2600 Service Pack 3 (32-bit)
DirectX :   Version 9.0c  (May 2010)
Cheers
Javy3
« Reply #5 on: June 17, 2013, 09:54:24 am »
I finally resolved my problem.  I went and downloaded the NullDC v1.0.0 beta 1.6 and that allowed me to finally get my emulator up and running at a correct speed.  This version has more sound plugins so I could play around to find the one that worked best.
Peja
« Reply #6 on: June 17, 2013, 01:12:46 pm »
Javy,
Do you have just one joystick/set of buttons running on it or are you going to use 2,3,4??
Also, do you have it set up so you can save?
Peja
stigzler
    • Mago Arcade
« Reply #7 on: June 17, 2013, 05:37:40 pm »
Finally found a solution! Tried the older version - compatibility issues for some games.
Some fella's optimised the latest build. Downloaded and worked perfectly 1st time for all games :D
Guy's a magician I guess!
http://www.ngemu.com...ad.php?t=151606
Hope this helps - yay! the end to weeks of frustration!
Peja
« Reply #8 on: June 18, 2013, 12:04:08 pm »
Same question applies to you stigzler:
Peja
stigzler
    • Mago Arcade
« Reply #9 on: June 18, 2013, 06:23:49 pm »
Save's working fine. Had no probs setting up 1 controller, but will check on two at some point and update
Peja
« Reply #10 on: June 18, 2013, 06:29:55 pm »
Thanks, I would appreciate it.
Peja
twistedsymphony
  • Last login:February 03, 2024, 11:13:51 pm
  • Play stupid games... win stupid prizes.
    • solid-orange.com
    • CollectorsEdition.org
« Reply #11 on: June 19, 2013, 03:11:05 pm »
your link is broken, any chance you could post a working link I'm really interested in this  :cheers:
  • Last login:Yesterday at 10:35:01 pm
« Reply #12 on: June 19, 2013, 03:29:00 pm »
This is the full URL.
« Last Edit: June 19, 2013, 03:31:54 pm by PL1 »
twistedsymphony
    • solid-orange.com
« Reply #13 on: June 19, 2013, 10:37:34 pm »
Thank you  :cheers:
stigzler
    • Mago Arcade
« Reply #14 on: June 20, 2013, 03:33:58 pm »
Eeeep. Sorry - bleary eyed and ruing having to work when posted. I was probably researching into washer types or something that night! Jees - all I wanted was a wooden box to play 1942 on. ;)
Be interested to know if this build works commonly for other people.
Good luck
