Author Topic: Nub Groovy Mame questions (monitor presets & INI Questions)  (Read 4355 times)
epicfatigue
  • Last login:May 15, 2016, 08:16:08 pm
    • http://www.retromods.com.au
Hey All i have a few nub questions,
So i have just compiled the new groovymame with the patches and high scores fix (YEAH!!!!!!!!!!!!!!!)
And i also downloaded the new Vmmaker as instructed and i see k7000 has finally been fixed but i have a question, do i set the monitor prefix to be k7000 in Vmmaker ini or Groovymame ini?
(sorry guys i always forget)
My other question is now that i am almost finished my rotating monitor system, how can i create an INI that all vertical games are displayed the correct orientation and do i have to alter something in Groovymame to make this select the correct res or will it auto do it for me?
Thanks Guys
Calamity
  • Moderator
  • Last login:Today at 04:18:33 am
  • Quote me with care
Re: Nub Groovy Mame questions (monitor presets & INI Questions)
« Reply #1 on: June 04, 2013, 01:08:38 pm »
Hi epicfatigue,
In vmmaker.ini, just leave the default options if your going to use a k7000 (we don't have this preset available yet in vmmaker, but default settings will work fine).
Then, the important step is to set "monitor k7000" in GroovyMAME's ini, as this overrides the generic modelines created by VMMaker with your selected preset (k700 here).
As for the rotating setup, make sure to create the resolutions with this settings in vmmaker.ini
MonitorHorizontal = 0
RotatingDesktop = 0
This ensures that both horizontal and vertical games are considered with their native resolutions.
Then in GroovyMAME, select either "orientation rotate_r" or "orientation_rotate_l", depending on the direction your monitor rotates (so games don't end up upside down).
Steps to create a log:
epicfatigue
« Reply #2 on: June 04, 2013, 07:24:47 pm »
Hey thanks Calamity,
Quick question but.
I am running compiled mame using the lastest patches with groovy patch etc as listed in the sticky thread.
I dont see those options in there, for vertical monitor setting.
Here is my ini file.
Code: [Select]
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
rompath                   C:\Roms\mame\roms\
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
memcard_directory         memcard
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
hiscore_directory         hi
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               0
sleep                     1
speed                     1.0
refreshspeed              0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   1
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              1
use_backdrops             0
use_overlays              0
use_bezels                0
use_cpanels               0
use_marquees              0
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
antialias                 1
beam                      1.0
flicker                   0
# CORE SOUND OPTIONS
sound                     1
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     0
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
log                       0
verbose                   0
update_in_pause           0
debug                     0
debugscript
debug_internal            0
# CORE MISC OPTIONS
bios
cheat                     0
skip_gameinfo             0
uifont                    default
ramsize
confirm_quit              0
ui_mouse                  0
autoboot_command
autoboot_delay            2
autoboot_script
# CORE MKChamp OPTIONS
disable_hiscore_patch     0
disable_nagscreen_patch   0
disable_loading_patch     0
# CORE SWITCHRES OPTIONS
modeline                  1
monitor                   k7000
orientation               horizontal
connector                 auto
interlace                 1
doublescan                1
cleanstretch              0
changeres                 1
powerstrip                0
lock_system_modes         1
lock_unsupported_modes    1
refresh_dont_care         0
dotclock_min              0
sync_refresh_tolerance    2.0
frame_delay               0
lcd_range                 auto
crt_range0                auto
crt_range1                auto
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
# WINDOWS DEBUGGING OPTIONS
oslog                     0
watchdog                  0
debugger_font             "Lucida Console"
debugger_font_size        9
# WINDOWS PERFORMANCE OPTIONS
priority                  0
multithreading            1
numprocessors             auto
profile                   0
bench                     0
# WINDOWS VIDEO OPTIONS
video                     d3d
numscreens                1
window                    0
maximize                  1
keepaspect                0
prescale                  1
waitvsync                 0
menu                      0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 0
# DIRECT3D-SPECIFIC OPTIONS
filter                    0
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable               0
hlslpath                  hlsl
hlsl_ini_read             0
hlsl_ini_write            0
hlslini                   %g
hlsl_prescale_x           0
hlsl_prescale_y           0
hlsl_preset               -1
hlsl_write
hlsl_snap_width           2048
hlsl_snap_height          1536
shadow_mask_alpha         0.0
shadow_mask_x_count       320
shadow_mask_y_count       240
shadow_mask_usize         0.09375
shadow_mask_vsize         0.109375
curvature                 0.0
pincushion                0.0
scanline_alpha            0.0
scanline_size             1.0
scanline_height           0.7
scanline_bright_scale     1.0
scanline_bright_offset    0.0
scanline_jitter           0.0
defocus                   0.0,0.0
converge_x                0.0,0.0,0.0
converge_y                0.0,0.0,0.0
radial_converge_x         0.0,0.0,0.0
radial_converge_y         0.0,0.0,0.0
red_ratio                 1.0,0.0,0.0
grn_ratio                 0.0,1.0,0.0
blu_ratio                 0.0,0.0,1.0
saturation                1.0
offset                    0.0,0.0,0.0
scale                     1.0,1.0,1.0
power                     1.0,1.0,1.0
floor                     0.0,0.0,0.0
phosphor_life             0.0,0.0,0.0
# NTSC POST-PROCESSING OPTIONS
yiq_enable                0
yiq_cc                    3.59754545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     0.0
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
# VECTOR POST-PROCESSING OPTIONS
vector_time_scale         0.0
vector_time_period        0.1
vector_length_scale       0.9
vector_length_ratio       4.0
# BLOOM POST-PROCESSING OPTIONS
vector_bloom_scale        0.3
raster_bloom_scale        0.25
bloom_lvl0_weight         1.0
bloom_lvl1_weight         0.21
bloom_lvl2_weight         0.19
bloom_lvl3_weight         0.17
bloom_lvl4_weight         0.15
bloom_lvl5_weight         0.14
bloom_lvl6_weight         0.13
bloom_lvl7_weight         0.12
bloom_lvl8_weight         0.11
bloom_lvl9_weight         0.10
bloom_lvl10_weight        0.09
# PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# FULL SCREEN OPTIONS
triplebuffer              0
switchres                 1
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# WINDOWS SOUND OPTIONS
audio_latency             2
# INPUT DEVICE OPTIONS
dual_lightgun             0
« Last Edit: June 04, 2013, 07:28:30 pm by epicfatigue »
epicfatigue
« Reply #3 on: June 07, 2013, 08:54:57 pm »
Any ideas anyone :( want to start playing my vertical games.
I have my own complied mame following the steps outlayed in the groovymame sticky.
Does it not have the options required for this do i need to go back to my original settings/???
Calamity
  • Moderator
« Reply #4 on: June 09, 2013, 09:46:44 am »
Hi epicfatigue,
If you've properly applied the patches and compiled your GM binary, launching it from command line with the -cc command should create a fresh mame.ini with a section named "CORE SWITCHRES OPTIONS" where you have all the options you need. If you can't find these options, something went wrong with your compilation.
epicfatigue
« Reply #5 on: June 10, 2013, 07:38:34 pm »
Bugger i will re compile again see if it helps quick question but,
I have a automatic rotating monitor, so it is going to rotate depending on the game, how to i set groovymame to have the orientation correct as rotate_l or rotate_r will only set it correctly one way,
Thanks mate
Calamity
  • Moderator
« Reply #6 on: June 12, 2013, 05:31:29 pm »
monitor rotate
orientation rotate
... will preserve the original orientation (so some games will be upside down unless your monitor can rotate in both directions)
« Last Edit: June 13, 2013, 05:00:47 am by Calamity »
epicfatigue
« Reply #7 on: June 12, 2013, 08:34:31 pm »
hrm iv re compiled same options re downloaded re compiled same options....
Downloaded the pre built groovy mame same options.
I can not find these switches you speak of in the mame ini file. i have generated a new ini each time.
Could you please post your ini file so i can have a look at it please.
So far the only way i have kind of got it to work is to create a vertical.ini and set monitor orientation to vertical
« Last Edit: June 12, 2013, 09:33:23 pm by epicfatigue »
Calamity
  • Moderator
« Reply #8 on: June 13, 2013, 05:03:45 am »
That's not possible I'm afraid :)
Post your mame.ini as an attachment.
epicfatigue
« Reply #9 on: June 15, 2013, 07:07:26 am »
aha
orientation rotate
that did the job perfectly thank you so much!
