Author Topic: Virtual Cop 3 peddal to Ipac  (Read 2002 times)
MAME TIME
  • Last login:March 23, 2019, 10:23:19 pm
« on: May 31, 2013, 08:24:21 pm »
Hey guys im just wondering how this could be done, I thought that it was a microswitch before I took it apart, is it possible to connect this up to an ipac?? some pics
Too Much Game, check out my ish!!!
Geometry Arcade
Neo Geo 360
MK2 standup
SF2 champ edition X2
paigeoliver
  • Awesome face!
Re: Virtual Cop 3 peddal to Ipac
« Reply #1 on: May 31, 2013, 08:53:14 pm »
Get a multimeter and test continuity between the various wires while pressing the button to see if any of them trigger without power, however I have a feeling you are going to need to feed +5 volts on one of the lines.
WindDrake
  • Last login:December 03, 2020, 09:49:05 pm
  • Electrical Engineer
« Reply #2 on: May 31, 2013, 09:09:07 pm »
Edit: Just realized it's a beam-break unit. Totally doable. If you're not scared of wiring some stuff up, it's doable.
Edit 2: If that thing is just a phototransistor, why in the hell does it have 3 wires coming out on the right side?
« Last Edit: May 31, 2013, 09:16:34 pm by WindDrake »
MAME TIME
« Reply #3 on: May 31, 2013, 09:13:18 pm »
pm'ed
Geometry Arcade
Neo Geo 360
MK2 standup
WindDrake
« Reply #4 on: May 31, 2013, 09:42:59 pm »
Did some reading. It's a photodetector, which means there would be some work to do in order to hook it up to your IPAQ.
If it's just a photodetector, we'd have to figure out if the beam-break makes a digital high or low, then either feed that into an inverter or leave it alone and shove it right into the IPAC.
It's all 5v, so you'd feed the device on the left +5v on red and Ground on black (2-pin). This is the emitter.
The device on the right (3-Pin) should be +5v (Red), Ground (Black), and Detect (White).
Hook up power and ground, then use a meter to see what the white wire does when the beam is broken vs. unbroken. If it goes to 0v when broken, you're in business and can hook the white wire to your IPAC directly. If it is normally 0v and goes to 5v when the beam is broken, you'll need an inverter.
Edit: VC3 Cab Manuals if you're ever interested. http://www.sauservice.com/manuals/VirtuaCop3/VC3main.html
« Last Edit: May 31, 2013, 09:46:08 pm by WindDrake »
MAME TIME
« Reply #5 on: June 01, 2013, 01:55:40 pm »
I should be able to use the PSU from the pc to power this correct?? something like this??
« Last Edit: June 01, 2013, 03:15:08 pm by MAME TIME »
Geometry Arcade
Neo Geo 360
MK2 standup
WindDrake
« Reply #6 on: June 01, 2013, 09:42:17 pm »
Should work, yep.
MAME TIME
« Reply #7 on: June 04, 2013, 11:16:23 pm »
worked like a charm, thx Drake!!
Geometry Arcade
Neo Geo 360
MK2 standup
WindDrake
« Reply #8 on: July 27, 2013, 05:40:54 pm »
Just saw this, glad to see it worked!
