Author Topic: Broke My Donkey Kong  (Read 6843 times)
curtis-r
  • Last login:February 07, 2026, 12:04:07 pm
« on: May 22, 2013, 10:25:28 am »
I have a 2-board upright DK unit.  I'd been having some alignment display issues and realized that one of the pots for horizontal position was replaced with a fixed resistor.  I have an extra DK board from long ago, so I took the pot from that one and replaced the fixed resistor.  I made things worse (no photos, sorry), so I decided to switch back the pot and use the old board, which I think only had a bad EEPROM, so I swapped those.  Now I've really messed things up.  Any ideas what I screwed up based on this photo?
Re: Broke My Donkey Kong
« Reply #1 on: May 22, 2013, 11:11:32 am »
Looks like you made it into a Super Breakout board.  Just a guess.
curtis-r
« Reply #2 on: May 22, 2013, 11:56:27 am »
Then can you help me get the paddle working  ;)
Gray_Area
  • -Banned-
  • -Banned-
« Reply #3 on: May 22, 2013, 04:25:46 pm »
Klov folk'll probly know exactly what's going on.
-Banned-
curtis-r
« Reply #4 on: May 22, 2013, 05:15:20 pm »
Who?  I can't find a member by that name.
Furry131
  • Last login:January 10, 2020, 10:55:54 am
« Reply #5 on: May 22, 2013, 06:19:51 pm »
Klov is a site
 http://forums.arcade-museum.com/
But there is a few people on there that are on here.  Be patient I'm sure someone will know what you did
curtis-r
« Reply #6 on: May 22, 2013, 07:19:49 pm »
Man, I feel like such a newbie.  My MAME and arcade cabs have been so stable that I've been out of this world for too long.  I now remember KLOV & will try that site too.  Thanks.
curtis-r
« Reply #7 on: May 23, 2013, 10:41:01 am »
Good idea on KLOV.   I started the following thread & got a bunch of help.  Unfortunately I think I may have fried an EPROM, but I have a little more debugging to do.
http://forums.arcade-museum.com/showthread.php?t=276235
dirt
  • Last login:October 30, 2024, 08:36:38 pm
« Reply #8 on: May 23, 2013, 10:27:48 pm »
WANTED: NINTENDO CABINETS WORKING OR NOT
mgb
  • Last login:Yesterday at 10:06:29 am
  • North East, US
« Reply #9 on: May 23, 2013, 11:59:42 pm »
Just as a good precaution, you can also try reseating all socketed chips and verify they're in correctly as this can be an easy way to fix issues before going too deep.
« Last Edit: May 24, 2013, 12:02:01 am by mgb »
« Reply #10 on: May 24, 2013, 10:21:05 am »
Reseating a chip doesn't fix anything.  It only temporarily reestablishes a bad contact.  If reseating a chip brings anything back to life then the socket needs to be replaced.
mgb
  • North East, US
« Reply #11 on: June 02, 2013, 03:19:01 pm »
Thats not entirely true. Pulling a chip, cleaning the legs and reinstalling can fix the problem. all poor contact issues are not bad sockets.
of course if socket is bad, then it should get replaced
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #12 on: June 12, 2013, 09:23:15 pm »
Congrats on getting to the kill screen.
NO MORE!!
« Reply #13 on: June 17, 2013, 09:58:11 am »
In this scenario you have put a clean leg back into a dirty socket.  The corrosion is not removed.  It's just reduced.  It will come back and you'll have the same problem later.
Karetaker
  • Last login:July 28, 2022, 08:19:40 pm
« Reply #14 on: September 16, 2013, 07:57:59 pm »
Before you go to crazy make sure all the pins are actually in the sockets. Also make sure you didn't bend any pins under. You will have to pull them back out to check for a bent under pin. I would check that before anything.
