Author Topic: nullDC 1.6b after run Mala ''how to hide mouse curser out off screen''  (Read 5341 times)
Almighty
  • Last login:October 28, 2013, 04:42:59 pm
    • Mighty Cade
After some day's working i finally got nulldc working in Mala.
no esc key, just hotkey in Mala (ALT+F4).
and changed something in cfg nulldc so the game loads automatic.
Only when the emu started the mouse curser is back in the screen and i have to connect my mouse (again) or i will buy a wireless mouse for this.
i also have hide mouse curser (program) only without succes.
How can i solve this little problem???
here some pictures from the setting's in Mala:
I really don't know how i get those ''emulator presents'' , only i can say i am happy with it because now nullDC run's automatic in Mala.
esc key nulldc (i am using i-pac)
with this setup you can kill ''nulldc'' in Mala (ALT+F4)
So now only the ''mouse curser'' left, so if someone know's how to solve this little problem, that would be awesome.
Thank you,
Been a while since I messed with NullDC.  I don't remember it doing that, but it was probably an old version.
Had the same issue with Demul 5.7 though, and I used nomousey.exe (it's just a compiled ahk script)
http://www.autohotkey.com/board/topic/2083-nomousy-disablehide-your-mouse-pointer-cmd/
I'm using it as part of a batch file, but I'll give incorporating it in Mala a try:
Pre-command:  start nomousy.exe /hide
Post-command: nomousy.exe
Almighty
    • Mighty Cade
thanks, :)
where do i have to put the AHK file? (in Mala) or nulldc. (map name?)
till now still that horrible mouse curser in screen.
I would guess in the nulldc folder.  (it should be a .exe not .ahk)
Mala seems to find and launch closemul.exe just fine when it's in the emulator folder.
Like I said, I'm using it via a batch file and haven't tried to incorporate it into Mala.
It might take some experimenting on your part to get it working.
If it doesn't work, try putting start nomousy.exe /hide on the main command line instead of in pre-commands.
Just put it first, then a space after it, then the rest of your command line the same as it is now.
Almighty
    • Mighty Cade
k i try this in command line also
start nomousy.exe /hide (/h -h h hide etc.) :banghead:
and without any succes.
So hard this would not be to completed, or i will use my wirless mouse to move the curser.....
i have put the files in my nulldc folder and data and in Mala so he has to pick one i quess.
I hope someone else got a clue, i know it is something easy to fix this now i have this running in Mala after 4 days of working.
Almighty
    • Mighty Cade
o.k,
i am back too nulldc 1.0.3 so when it launch the mouse curser is no more ;D
only sometimes when i quit game i get this message:
in _mmu nulldc_ 1.0.3 has encountered a problem and needs to close. We apologize for this inconvenience.
when i press the esc key again in Mala it will go away and i can choose another game so the pc is not crashing.
Is this normal? it won't happen all the time, just a bug in nulldc??
« Last Edit: April 30, 2013, 01:46:35 pm by Almighty »
